I was trying to rotate the tires but couldn't take off the wheel after I took the bolts out, is there another bolt behind the center cap? Because it was stuck pretty good and didn't want to pull too hard since all 4 tires where off the ground. :laugh:
It's probably rusted on. Give the tires a good kick.
I remember another member having the same problem. :yesnod:
Suggestion - apply a *thin* coating of high temperature grease on the hub, before you put the wheels back on. It'll be easier to remove next time.
Just don't use too much, or it will splatter all over the place =)
Ok thanks.. I'll give it a good kick! :guns:
