Most common problem with this code is the gas cap was loose or it has failed to hold a vacum.
This code is a Two OBDII Trip code. Two drive cycles need to be complete before the computer will determine if there is a problem. This light will not set after ten minutes, unless, the computer was already going to kick out the code and you just happened to fill up the tank.
Note: Please people don't fill your tank with the car running, that is a hazard to yourself and everyone around you. Thanks
If you want go to Autozone and have them clear the code. Buy a new gas cap and see if the light comes back on. Our shop has a gas cap tester and would happily test it for anyone.
If the light comes back on you should get it checked out
P.s. The reason gas stations say do not top off the gas tank is because inside the gas tank there is a fuel tank pressure sensor. The computer uses this sensor in conjunction with other components to determine if there is a leak by putting a vacum on the gas tank and monitoring the pressure sensor for a significant drop. When the gas tank gets topped off it ruins this sensor.
65% of the time the gas cap was loose/bad
10% Fuel pressure sensor
10% EVAP Vent Solenoid
10% Purge Solenoid
5% Vapor Management Valve
Note: These statisitics are a rough estimation of what we see at our shop for every make and model we work on
