1 - 3 of 3 Posts
I just got my 6 with bose option 1 month ago. Today the cd player couldn't change the disc and couldn't play any disc. I have listened those cds since I got the car. So, I did lots of research and some posts said reset the fuse. OK..I did and the situation got worse. The CD player only showed "NO DISC" after I reset the fuse and then didnot respond any button except "load"...but there were already 6 discs inside :tear:
Should I go to dealer to get fixed or there is any other way to reject the cds?
Thanks a lot..
have you tried disconnecting the battery?
i've had a few of 'no cd's' show up but after turning the radio on/off it works or use a different brand cd.
the one's that i've gotten stuck with was one with a cd label i put on. so i never used those again.
if you cant get it to work again set an apt with the dealer.
Yes...I have. I have tried disconnecting the battery and the fuse (#34) reset with no luck...
Looks like its a common problem and I will call dealer to ask replacement...
I am going to get iPod mod as soon as possible...
1 - 3 of 3 Posts
