Replying to Topic 'Cargo net'
Just bought it and installed it.
1. There is a drilling involved. You'll need 2 drill bits: 8mm (5/16") and 13mm (1/2") drill bits
2. The instruction was pretty confusing. You have to use smaller bit to drill hole in the metal and bigger bit to drill in plastic trim.
3. Be careful pulling out the trim piece and don't break the plastic pins it is attached on the bottom.
4. Collect the metal shavings into a towel if you don't want to take out mat and clean it afterwards.
I'm used to having cargo net in my other car Nissan Altima, so I had to install one in the M6. Very convenient feature!
