1 - 2 of 2 Posts
While driving my car radio and interior lights went out. When I turned the car off, it would not turn back on. Power locks wouldn't work, key fob wouldn't work, interior lights wouldn't work and couldn't start the car. It wouldn't even make an attempt to start, almost as if I wasn't pushing the button at all. It wouldn't work with the physical key either. I take it in and they claim my battery had a dead cell (even though I tested it at 12 V). It starts working once they replace my battery but when I drive it a couple days later, the same issue occurs. I immediately take it back
They claim its a blown fuse (I don't know how that fuse magically un-blew and worked again) but I'm out of ideas. Does any one have any ideas of where to start looking? I'm thinking it's a connection issue
Any help would be really appreciated!
The usual comment you'll get here is to check the grounding connections. You should see the negative terminal leading to the car's body. Try to remove it and clean the area then securely connect it.
1 - 2 of 2 Posts
