1 - 2 of 2 Posts
Installed them yesterday, everything works and looks great, EXCEPT the drivers side turning signal doesn't work at all.
Only wire I cut into, was the Green/Yellow Stripe wire to do the brake light mod. Any suggestions?
Discussion Starter · #2 ·
Double checked the install, everything is def correct, however, the connector coming off of the turn signal bulb had one of the two metal conductors was slightly pulled out. Essentially, its just a connector, so I could cut those wires and make my own connections? Right?
1 - 2 of 2 Posts
