I didn't see it in my manual, but I was wondering if someone could give me the placement of all 6 cylinders in the 3.0
(I need to replace my #1 coil and want to make sure I change the correct one :p )
When you take the engine cover off youll see the wires are actually labelled. If I remember correctly, #1 is on the rear of the engine so I'm not sure its something you can do yourself.
Discussion Starter · #4 ·
Changing the rear coils is no harder than changing the plugs..
You can pop off the intake in under 5 min....
Had to do it to replace the fuel rail.. :(
OK..
I have the cover off and the front 3 wires have no labels, but from what I can see the rear 3 do and it looks like the rear pass side is #1 and the rear drivers is #3 (so I assume the middle one would be #2)
Anyone know how they are in the front?
(If I had to guess it would be 4 in front of 1 and 6 in front of 3, but could someone verify this?)
