1 - 7 of 7 Posts
I just got my MS6 and being as 93 octane is the lowest i should use would it hurt to use 100 octane? I know its expensive i just wonder how the MS6 would run with a 98-100 octane
Yes you can run 100+ octane in your MS6 provided it is not leaded gasoline. From my own personal experience 95ish octane is where the sweet spot is in throttle response/timing advance/SOTP feel.
yeah in my area the only options are 93 and 100 for high octane so i guess i could do 50/50 and split the difference right
From what I have read on the subject, it is always prefered to have unblended gasoline straight from a large source. This is rarely available however in the octane range you are looking at and is mainly for consistancy's sake. Out here in Cali all I can seem to find is 91 and 100 (at select 76 stations) at the pump unless I want to have a drum of gasoline delivered to my house from somewhere like Sunoco or VP Racing Fuels so personally I mix them.
Yes you can but there's no need to unless you rebuilt your engine.
Racing cars run 100 octane. FYI
You don't need to rebuild an engine to receive any benefits from high octane fuel, especially in a forced-induction application. At minimum, running 100 octane will just cost more and add a little extra insurance against detonation.
I used to run 106 leaded in my Eclipse and simply turn up the boost about 5psi higher than normal and I rarely saw any knock. A tunable ECU is even more advantageous in this situation as I kept adding timing and leaning out the injectors and still no knock. On 93 octane I would have blown the engine at those settings.
Plus it (100+ leaded fuels) smells goooood :)
1 - 7 of 7 Posts
