I ran into the following issue when removing(attempting to remove) a broken water-pump housing. As others have mentioned, the water-pump drive pulley on the cam blocks two of the three mount bolts for the pump on the Mazda 3.0. Although I found several threads discussing the problem my brief forum search did not uncover any info on removing the drive pulley.
Can the pulley be removed from the cam, how, with what tools?
Would camshaft removal be simpler?
This rookie mechanic appreciates any and all advice/info.
