1 - 7 of 7 Posts
Hi
Does anybody know if there is a shim for the camshaft position sensor - when reinstalled it did not fully seat. The bolt is correct but seems to be bottoming out. I am going to add washers unless it' supposed to set out a bit.
thank you
Hi
thank you
Hello, while I cannot say for sure, it does not sound like this would be the case.
The diagram for the 2014 only shown an o-ring.
CAMSHAFT POSITION (CMP) SENSOR REMOVAL/INSTALLATION [SKYACTIV-G 2.5]
My 2004 requires a "perfect" insertion of those sensors, for them to insert completely. Perhaps you angle is little off.
Drive it for a couple days now and no leaks - I might be overthinking this a bit
240039
1 - 7 of 7 Posts
