1 - 3 of 3 Posts
hey guys so i just fixed my brakes since i worn out the rotor after my accident that fucked up a lot of things on the front driver side disc. i changed out the pads and with a grand sum of $450. my alignment needed to be readjusted because the front camber is at -2 on the left and -1.2 on the right.
the caster is at 2 on the left n 4.6 on the right
the toe is at -1.42 on the left and 0.32 on the right
basically what happened was after running over an island head first in a lowered car everything went to shit. the frame is also bent as well. the front driver side tire is sitting about a finger width further back than on the front passenger side.
the mechanic i spoke with says they will need a machine to pull the frame back out which would cost about 200-300 bucks or a camber kit that has a caster adjustment would work as well.
where can i get a camber kit with caster adjustability? would this be cheaper than getting the frame pulled? it has already eaten away one fresh tire in 2 months. i am pissed.
you can't get one because they aren't made. Mazda_gremlyn was trying to get one made, but there wasn't enough interest.
Do it the proper way and have the frame straightened
even if you find such an item (as far as I know no such part exists) you'll be far better off to get the frame square and do the repair correctly.
1 - 3 of 3 Posts
