Has anyone with the mazdaspeed6 CAI had the mounting bracket come loose.? If you've installed the CAI then you know that the bracktet that connects the tube assembly to the frame has a one-sided , open ended bracket. My question is, can that come loose and leave the entire intlake rubbing on the chassis?
When we installed the CAI, we noticed that the tighter we torqued it, the looser it became. I've pretty much decided that I'll check the connections weekly, however I"d like to know if this is necessary.
Thoughts?
Thoughts?
