Wat bulb is the reverse lights. I went to a place and they only had a red one and on the box it did not say wat type it is, and if nebody knows a place i could get the xenon ones i would appreciate it.
Also, I succesfully have replaced my front turn signals, running lights and projectors lights, and I know how to replace the high beams too on the v6. It was not easy, the headlights on the driver side were the easiest. All those took was twisting the cap off and replacing the bulb, but on the passenger side i had to unbolt the three bolts and move the radiator tank (or watever that pink fluid is). And then i took off the cap. For the running lights and high beams you have to unlclip that bigger plastic piece in the middle, there is a clip on top u push that down and with some wiggling you can get it out and you just pull the running lights out. But it was a pain though my hand is all scraped up.
Thats all for now
Thats all for now
