1 - 8 of 8 Posts
That thing is NUTS. I can't wait to see the Stig get ahold of it on Top Gear. I'm guessing a lap time of around 1:12.5 or so.
:eek: :eek: :eek: :eek: :eek: :eek: :eek:
K
Guest
Crazy fast.
Did you guys see this article: http://auto.howstuffworks.com/bugatti.htm
1.33 gallons per minute!
From the article:
So let's start with the engine. How would you begin the design process for an engine this powerful? If you have read How Car Engines Work, you know that if you want to create a 1,000-horsepower engine, it has to be able to burn enough gasoline to generate 1,000 horsepower. That works out to about 1.33 gallons (5 liters) of gasoline per minute.
How much gas is that?
Here's a quick calculation, which you can ignore if you hate math:
* 1,000 horsepower is equivalent to roughly 2.6 billion joules per hour. A gallon (3.8 liters) of gasoline contains 132 million joules, so a 1,000-hp engine has to be able to burn just over 20 gallons of gasoline per hour.
* However, car engines are only about one-quarter efficient -- three quarters of the gasoline's energy escapes as heat rather than as power to the wheels. So the engine actually has to be able to burn at least 80 gallons per hour, or 1.33 gallons (5 liters) per minute.
* Let's convert over to metric. Gasoline requires about 14.7 kilograms of air to burn 1 kilogram of gas. Air weighs 1.222 kilograms per cubic meter at sea level. A gallon of gasoline weighs 2.84 kilograms. So the engine has to be able to process 2.84*1.33*14.7 kilograms of air per minute, or roughly 45 cubic meters of air per minute. That's 45,000 liters of air per minute.
* If a V-8 engine is turning at 6,000 rpm, it can inhale a total of 24,000 cylinders' full of air per minute. If it needs to inhale 45,000 liters of air per minute, it works out to roughly 2 liters per cylinder-full. That's a 16-liter engine.
1 - 8 of 8 Posts
