1 - 8 of 8 Posts
My glovebox will not open and I cannot find how to get it open. I found these directions:
1. Remove the plastic trim above the glove box. Held on via several tabs, comes off easily, start in the middle then work out towards the ends.
2. Carefully using two large screwdrivers and a thick washcloth, pry gently on either side of the metal lock/bar just above the glovebox handle (location can be easily seen with flashlight). Keep prying until it pops open, doesn't take much force.
3. Remove the glove box from the dash, just open and push-in on the two tabs (located on the side of the glovebox door). It comes right out.
4. Remove the three screws securing the glovebox door/lid lock mechanism. After removing the screws it comes right out.
5. There is a little plastic clip on the lock mechanism, it rotates when you turn the key and sets the lock or unsets it. This part is flimsy and the design doesn't allow it to sit properly in my opinion. It kind of floats in the mechanism and in my case simply lost contact with the tumbler. I'm surprised it hasn't happened to more folks who have locked the glovebox.
6. Just reconnect it, I also used a lttle heavy grease to help it stick to the mechanism a bit better. The light amount of lithium grease from the factory wasn't enough.
7. Reinstall the mechanism and test, if it works, put it all back together.
But the problem is with number 2. I cannot find where i need to pry above the handle. I tried doing so and nothing happened? Anyone have a better explanation or pictures?
is it locked? just askin, you never know...
^^^good question
Did you do step 1 and remove all the plastic trim? If you didn't, you wouldn't be able to see step two.
I've had something similar happen in an older car i had. someone tried breaking into it and broke the lock, had to take apart a few things in order to get the damn thing open. similar to the steps you posted above.
First thing to do is to see if the key works on it and you can open the glove box. Does the locking mechanism turn freely? Or is it just jammed? Are you using the Valet key? valet key does not open glovebox, as far as I know.
Yes, check to see if it is locked and also try different keys.
^I think the OP might be trapped in his glove box..
I had the same thing happen to me. Locked it and when I unlocked it, it still wouldn't open. I pulled off the gray plastic piece above the glovebox and pried it open. It was covered under warranty so I got a new one. Like stated above its a very cheaply designed latch.
1 - 8 of 8 Posts
