where's dabears2k when you need him?
right here :wavey:opcorn: wait for it...wait for it...
i would imagine hawks dust more than stock, no?Hawk.
therpmstore.com
right here :wavey:
the hawks for the 6 have VERY LITTLE dust. It takes me about 3 weeks with the hawks to get the same dust as 4 days with stocki would imagine hawks dust more than stock, no?
i guess i'm not sure about the hps, but i know the hp+ dust pretty well... i use those on my rx7, and that stuff builds up fast when i'm on my brakes...
hp+ or hps?the hawks for the 6 have VERY LITTLE dust. It takes me about 3 weeks with the hawks to get the same dust as 4 days with stock
2006 Owners take note:i would imagine hawks dust more than stock, no?
EDIT: i just looked at www.hawkperformance.com and they don't have anything for the speed6... or the 6 for that matter... am i missing something? [/b]
Yup... I use Wheel Wax. You need to try it!!!! Advance Auto Parts has them.BTW: Putting some wax, any kind of wax, on the wheels does help in making the dust easier to get off.
I'm not sure you have accurate info there, I've seen plenty of cars less than $100,000 that brake as good or better than the Speed6. The Audi A4 in the March AWD shootout came VERY close to the same numbers as the Speed6 for example.i know that most people would presume that aftermarket pads would lead to better braking, but i would want to be completely sure about this one.
the mazdaspeed6, at least in measured stops from magazine testing, brakes unbelievably.
the speed6 brake's might be some of the best ever by mazda. for instance, they do a 70-0 stop in 155 ft as tested by C&D. to put that in perspective, the average cost of a car that can stop in 155 or so per their road test digest of all tested vehicles, was around $100,000.
now, i abhor the brake dust - no one likes having 1 gunmetal and 1 silver rim on each side, lol. but i am worried about losing the nice feel and performance.
You can't do direct comparisions from a list, the cars have to be tested same day, same pavement, several tries then averaged, same driver, hence a shootout test.the info is good...just took it out of the september 2006 car and driver road test digest.
of course there are cars less than $100,000 that brake similarly or a bit better...otherwise my average price would have been much higher. the GLi for example, costs about the same as the speed6 and helps offset the average from the $240,000 ferrari f430 which stops only 4 feet sooner.
now, i understand there is more to braking than just 70-0 and fade resistence, but Gli excluded, youd have to spend at least $57,000 to find a car that brakes the same from 70-0 as the speed6. (EDIT: i added a bit of a buffer zone from 155 up as well, just to keep the numbers honest, and the results didnt really change)
there's just something i like about knowing a documented car and driver test found my car to stop more quickly from highway speeds than a: porsche 911 turbo s, bmw m5, corvette z51, 612 scaglietti, etc etc
anyway, i think my point comes through, im just trying to get the info/opinion out there for discussion. it just surprises me that the braking isn't more lauded.
as far as the a4, the digest must have different results than the test printed, because i have it here as:
A4 quattro 3.2, $41,520, 7.5/15.7, top speed 130, braking 70-0 175ft
i wouldnt be surprised if car and driver uses the same testing grounds for most of their tests (provided they dont have to go to europe etc to test a new release). with abs and ebd, driver involvement in braking tests is pretty limited.You can't do direct comparisions from a list, the cars have to be tested same day, same pavement, several tries then averaged, same driver, hence a shootout test.
Don't get me wrong, the car seems to have very good brakes but it is not as world class in braking as your interpretation of the data you used might suggest.
Take your Z51 Vette number, several tests show a 60-0 of 110 ft for the Z51 and 121 ft for the Speed6, so..... [/b]
I've done it without ill effect, but ideally you want the same friction material on both front and rear unless you're doing some special brake setup and are factoring that in.back on topic...is it logical to replace just the front pads and leave the rears alone?
