I have a '03 6s with the manual transmission and when I would press on the brake pedal, the pedal would travel an excessive distance (below the gas pedal, made heel-toeing easy as a can of corn,) before the brakes would bite. When they finally would bite, the pedal felt firm but it didn't exactly install much confidence in the brakes.
I replaced the front pads with Hawk HPS and bled the brakes using a synthetic DOT 3/4 fluid. That didn't fix it, so I re-bled the brakes thinking I had screwed up. Still not fixed.
Explained this to a buddy of mine and he suggested adjusting the rod that is between the master cylinder and the brake pedal. (Letter C of attached diagram, thanks Crossbow, I stole it from one of your previous posts.) He said this was common on Ford trucks, the fire wall would deflect and bend from people slamming on the brakes.
I ended up adjusting it 3 1/2 turns before the pedal felt right under braking.
Has anyone else had this problem? Is this common for the 6? I have never had to do this on any other car I have owned.
Thanks.
[attachmentid=13246]
"Is this ALL the time? or the first application?
What happens if you tap the brake pedal, then apply the brakes?"
It was all the time. I could pump the brakes up while standing still. Tapping didn't seem to help.
