Can someone give some advise on how to test if the BOV leaks or not. I have installed the HKS BOV and I have no gauge, is there any other simple to test it out?
You can pressure test your whole intake. You'll need to make a pipe which fits on the turbo and creates a sealed environment. Add a tire valve stem to it and use a hand pump, or compressor if you must. Youll want to pump it up to ~17psi and see if it holds. Also listen for leaks.
This is a common way us turbo guys check for intake leaks when modding a car. Buy yourself a boost gauge though, it will normally tell you when something is going wrong.
If you need I can provide photos of the one I made for my Talon.
Jason
Thanks for your feedback Jason. I think the gauge become more impotant to me as I am wating for my CPE CAI to be delivered.
Btw, if the BOV leaks, how would it feel under hard acceleration? Is the engine still revving but the car not pulling hard?
If it leaks, you'll see a drop in boost. So, yes, it may not pull as hard. You may notice it, you may not, it's hard to say. Once you get a gauge, you'll see if it falls off or holds steady.
If the boost stays steady, but you can feel a drop off in power, the ecu could be pulling timing for some reason.
