1 - 11 of 11 Posts
SO I was changing my oil today and nothing out of the ordinary.
I got all the way to putting the new oil in, and I noticed DAMN I bought 10-30 royal purle instead of 5-30, and the stores are all closed...
So I didn't put the oil in.
Is it ok for my car to sit there overnight with no oil in it?????
BTW I was staring at oil bottles for about an hour, Is that royal purple stuff any good? It was that or mobil 1....And now I still have a choice.....
Thanks,
Randy
it will be fine just over nite
both are great oils probley the two best you can buy
It's absolutely fine to sit there overnight. There still is enough oil on the internal parts being lubricated that you should not have an issue.
Discussion Starter · #4 ·
I SHOULD NOT RUN THE 10-30, correct?
What about running 10-30 for a FLUSH? I have like 3 boxes of mobil 1 red cap I got for free 10-30...I won 10 boxes in a raffle, been using it to flush my motorcycle engine.
I wouldn't drive with the red cap 10-30, just fill, run it for a few minutes, and then empty it....
If I could use the red cap 10-30 permanently ohhh man I'd have my oil for the next 3 changes already....
I could have swore I picked up the right one.
Thanks
What about running 10-30 for a FLUSH? I have like 3 boxes of mobil 1 red cap I got for free 10-30...I use it to flush my motorcycle engine.
Thanks
You wont have any issues at all if you run the 10-30. It might cost you a couple of HP, but it definatly wont hurt anything.
I wouldn't personally for any significant mileage. Considering this is a turbo engine, you really need the right weight oil that can get 'thin' or 'thick' enough for the temps produced.
EDIT: Obviously, SS and I disagree and that's ok. I would check out www.bobistheoilguy.com for more opinions than my sorta-educated one!
Discussion Starter · #9 ·
hehe thanks guys. The car needs all of it's HP though....Mabey it's just me, from being used to riding a 160hp, 450 lb motorcycle. I have to sell it unfortunately...
I'm gonna have to get at least a cai :)
I was just looking through the manual....And I think I'm going to stick with the 5-30, but I'll use the 10-30 to flush. You are right it shouldn't hurt a thing...
From what I've read, the main reason all the OEMs are swithching to the 5-20 and 5-30 oils is to help meet emissions requirments and bump the fuel economy up a little.
Absolutely correct, 5-20 is a lighter-weight oil and yeilds a *little* better mileage than the heavier 10-30 or 10-40 mixes. Hell they even recommended it for my 5.4 triton in the supercrew. All comes down to CAFE standards
1 - 11 of 11 Posts
