1 - 20 of 45 Posts
Info from lawsjoe:
Pre-Amp out for Bose
Front Left-
+ Solid Black
- Solid Green
Front Right-
+ Solid White
- Solid Red
Rear Left-
+ Red w/silver dash
- White w/ silver dash
Rear Right-
+ Green w/ silver dash
- Black w/ silver dash
http://www.cardomain.com/memberpage/388592
# MAZDA'S STANDARD BOSE DESCRIPTION From HU
REFERENCE SYSTEM SYSTEM
here is the order of what you sould read: number, reference form Mazda(letter) Bose system color and description.
1 a RED BLACK LF+
2 b RED BLUE/RED Batterie +
3 c GREEN LF-
4 d RED RF+
5 e LGREEN/RED Data
6 f WHITE RF-
7 g BLACK/YELLOW Data
8 i GREEN/RED Illumination
9 j BLACK Remote
10 n RED/BLACK Steering
11 p GREEN/WHITE Steering
12 r ORANGE Accessory
13 s WHITE LR+
14 u RED LR-
15 v BLACK RR+
16 w BLACK/ORANGE Ground
17 x BLUE GREEN RR-
http://www.mazda6club.com/gallery/albums/u...cs/wiringHU.jpg
Below is a little more information on the subject. Much of the information was gathered from "Phatalone". Most is the same as original post with a few extras like speaker wire color to the speakers
Pre-Amp out for Bose To Speaker (not sure about + - on this side)
Front Left-
+ Solid Black Red/Silver double dash
- Solid Green white/silver double dash
Front Right-
+ Solid White Blue/Silver
- Solid Red yellow/Silver
Rear Left-
+ Red w/silver dash Pink/Silver stripe
- White w/ silver dash Purple/Silver stripe
Rear Right-
+ Green w/ silver dash White/Blue stripe/Silver dash
- Black w/ silver dash Black/Blue stripe/Silver dash
Black/Red stripe Sub
Blue/Black stripe 12v acc
Yellow/Black 12v constant or Batt
Brown Sub
Black/Orange stripe Ground
1 a RED BLACK LF+
3 c GREEN LF-
4 d RED RF+
5 e LGREEN/RED Data
6 f WHITE RF-
9 j BLACK Remote
13 s WHITE LR+
14 u RED LR-
15 v BLACK RR+
17 x BLUE GREEN RR-
2004 Mazda 6s Sedan w/ Bose Stereo Information
Front Doors
6.5" door panel cutouts
stock speaker size: 156mm
Impedance: 2ohms
.75" tweeters in door sail panel
Drop-in aftermarket replacements:
6.5" components with .75" tweeters
This a quite common size and should be very easy to get a good set of aftermarket speakers.
Rear Doors
5"x7" door panel cutouts
stock speaker size: 5.25"
Impedance: 2 ohms
5"x7" coaxials or woofers
5.25" coxials or woofers
Once again these are very common and should be very easy to get a good set of speakers.
Subwoofer
9" cutout
stock subwoofer size: 9"
Modified fit replacements:
Any sub woofer with a diameter under 9" should mount into this unit fine with an appropriate custom adapter. This would include most 8" subs that I know of. However, if you are going to run the subwoofer with out an enclosure behind it I would highly recommend that you ensure the sub is designed for infinite baffle setups. I have installed an 8" in the rear deck and the sound quality is very much improved over the stock sub and can provide a decent amount of bass without taking up much trunk space.
I have a JL Audio IB4 to put in there.. what did you use to make an adapter with to get it to work??
Please help!
Scott
Okay so if this is correct than the BOSE sub inputs are sourced back to the amp not the headunit. So if I want to run 2 amps I'd have to find a 4ch with a preout for the subs?
Has anyone already posted the pin out of the factory amplifier and not the head unit?
I don't want to waste the time writing it up if its already been done.
Factory Bose Amplifier Plug Pin Out:
Color Code above applies
http://www.msprotege.com/members/1sty/mazd...e%20ampplug.bmp
A - Rear Left Speaker Output (-)
B - Front Left Speaker Output (+)
C - Rear Left Speaker Output (+)
D - Front Left Speaker Output (-)
E -
F -
G - Front Left Head Unit Input (-)
H - Front Left Head Unit Input (+)
I - Rear Left Head Unit Input (-)
J - Rear Left Head Unit Input (+)
K - Front Right Head Unit Input (-)
L - Front Right Head Unit Input (+)
M - Rear Right Head Unit Input (-)
N - Rear Right Head Unit Input (+)
O - Subwoofer Amp Line Output (-)
P - Subwoofer Amp Line Output (+)
Q - Remote Turn on From Head unit
R -
S -
T -
U - Constant 12 Volt Power
V - Ground
W - Front Right Speaker Output (+)
X - Rear Right Speaker Output (-)
Y - Front Right Speaer Output (-)
Z - Rear Right Speaker Output (+)
Reactions: icyalata
Are there any pictures of the bose amp/hu with all the wiring connected?
This should be, at least on the 2005 Bose:
X - Rear Right Speaker Output - WHITE/BLUE (+)
Z - Rear Right Speaker Output - BLACK/BLUE (-)
Rick
I am trying to use the existing wiring for the Bose sub to hook up an Infinity Bass link. The Bose sub harness is in my hand and I have the following wires:
blue\red stripe
black
yellow
brown
black\orange stripe
I have searched this forum and the internet for an hour and have not been able to find a clear answer on what each wire is for. I assume the following:
blue\red stripe is constant power
black is ground
yellow is remote power
brown is rear +
black\orange stripe is rear -
Can anyone please tell me if this is correct???? I hooked the bass link up using this assumption and the amp did not power up. Any help would be appreciated.
blue\red stripe
black
yellow
brown
black\orange stripe
black is ground
brown is rear +
[snapback]525488[/snapback]​
i remember there being a "how-to" for this on mazda6tech since that's how i was able to do mine.....
http://forum.mazda6tech.com/viewtopic.php?...aftermarket+sub
although, this was for an '03 and i'm not sure whether the wiring has changed since then.
Thanks for the link skeurton! It helps some. The wire colors are a little different but it explains why my amp did not power up. It looks like I need to run a line from the battery to my trunk for constant power. You would think that the bose amp would need constant power and I could use that! If anyone else has more info for me it would be appreciated.
Thanks again! I'll give it a shot with using a wire directly to the battery along with the wires in the trunk. Once I get things working I will post exaclty what I did so this is crystal clear for everyone else.
Is it possible to use an aftermarket HU with the bose sound system?
I can't see why not. I used to hook aftermarket HU's up all the time to nissan bose systems. DOn't know if you would need a premium sound interface like others do.
Hi All,
Just stumbled across the site and havn't looked through in great detail yet as it is getting a little late
in the night.
Can I ask, how simple is it to install a Factory Bose system into a Mazda 6 Limited??
The Mazda 6 Limited 2004 only came out with a single HeadUnit and I came across a complete Bose
system that I want to install.
Generally speaking when you install factory acceories most or atleast some of the wiring looms are
already in place, is this the case on the 6 as well?
Any heads up would be appreciated!!
Info from lawsjoe:
Front Left-
+ Solid Black
- Solid Green
Front Right-
+ Solid White
- Solid Red
Rear Left-
+ Red w/silver dash
Rear Right-
so if i wanted to add an additional tweeter to the bose setup... i would just tap into the solid black and solid green for the front left speaker? or do i just use one line to tap into? sorry, i'm a newb when it comes to electrical things!
1 - 20 of 45 Posts
