1 - 15 of 15 Posts
So I recently bought a 2006 Mazdaspeed6 with 200k on the trans and a rebuilt gen 2 motor 80k miles ago I bought it completely stock but with an accessport, I bought a short ram intake and aftermarket turbo inlet cause the guy had it tuned with a stock air box. Anyways I was only pushing 12 psi with a stage one tune on (should be pushing 17) I replaced some boost lines but there were no obviously bad lines, then I replaced the boost solenoid which didn’t help anything, I then replaced the waste gate actuator which put me up to 13.5 with a stage one tune. Last night I was messing with the tunes and put on a stage one plus tune which is for a Aftermarket cold air intake and turbo inlet the peak psi for that is 16.5 but for some reason I was only hitting 12.75 psi idk why it dropped with a better tune Thought it could be my ecu not sure but the car runs mint doesn’t overboost and it doesn’t underboost it just runs to good to be a simple boost leak anyone else had a problem similar to this?
Discussion Starter · #7 ·
Cause I’ve driven in my friends speed3 and mine does not feel like that when you hit boost it’s way under power
Would you care to tell what the problem and fix was, am really interested to find out since I'm interested in buying a Speed6 down the line and I'm researching all kinds of pros and cons and situations of other owners!
Discussion Starter · #12 ·
It was my fuel internals haha they were shot I replaced them with auto tech internals that I got used for cheap and also put a corksport fuel line in now I’m pushing 20psi the ms6 is a fun ass car and it rips if you just keep up on General maintenance you’ll be chilling I daily mine and for 200k thing handles like a new car
I have a black 07 MS6GT bought new with 59K currently on the odometer, I have a similar problem, my boost is around 11 PSI, read from mechanical vac/boost gauge and Dash Hawk, both read close to the same. Boost goes up to 12, then pulls back. I don't know when this reduced boost started because I don't push it in boost often. Installed CorkSport HP fuel pump internals few weeks ago and CorkSport intake last year, boost was normal with the CS intake. Recently installed a TurboSmart blow off valve, and one size up on the tires when the originals were replaced. For appearance I replaced the tail lights with Spyder ALT-YD M603-LED-SM Smoke LED tail lights. With black paint and light tint tail lights, these after market tail lights look like they belong to the car, not add on's.
I had this low boost years ago when I broke the fitting on the stock air box that goes to the waste gate controller. I had an EGR issue and working it, the fitting got broken, not uncommon to happen. I repaired it but inadvertently blocked the fitting hole with JB weld during the repair. Drilled that out after figuring out what I did wrong and boost went back to normal.
Having owned this car for 13 years I still enjoy it. But buying a high mileage version may be a money pit, the person has to be willing to put money into this rare car. Mine is near perfect. I keep a black "A" shirt on the seat back to protect the drivers seat back bolster to protect it.
Discussion Starter · #15 ·
I would check for a boost leak but 12 psi would be a pretty extreme boost leak you would probably throw a code do you hold boost fine or does it drop more than 1.5psi
1 - 15 of 15 Posts
