1 - 8 of 8 Posts
Is it truth that using a bigger rims eg. 17" tyres consume more petrol than a smaller 15" ?
Replying to Topic 'Bigger rims = more petrol consumption'
QUOTE
Originally posted by jon
            Is it truth that using a bigger rims eg. 17" tyres consume more petrol than a smaller 15" ?[/b]
No, as far as I know the diameter of the rim has nothing to do with fuel economy. This conception might have originated from the fact that with larger rims you usually use wider tyres that slightly increase drag and therefore also the fuel consumption. The difference in consumption should be minimal if you stay within reason with the tyre width.
That's right. Diameter of the rim has nothing to do with fuel consumption.
But the tires on 17" are bit wider than 15". For example - available tyre dimensions
for Mazda 6 in Europe are:
195/65 R15 (doesn't look good at all)
205/55 R16
215/45 R17
So the difference in width is quite small. My Mazda6 has 215/45 R17 and
fuel consumption is Ok (more precise data in "Anything wrong" folder).
QUOTE
Originally posted by Gasjs
195/65 R15 (doesn't look good at all)[/b]
Agree, but at least in Estonia the overall quality of roads is nothing to be proud of (and I also drive a lot on gravel roads because of my work) so having 215/45 R17 tires would be just torturing yourself and the car. Broken rims are also an issue with huge potholes we have (just kidding - its not that bad, but not much better either :().
I went for the 15" steel rims initially and plan to get a set of larger alloys later on (will probably settle for 16"). In here we use studded snow tires in winter and I plan to leave steel rims for winter driving. I think it makes sense to have two different sets of rims if you have to change tires twice a year. As a bonus you get better grip with narrow/higher profile tires in winter and wider/lower profile tires in summer. Plus there is a chance of ruining tire and/or rim with constant interchanging of summer and winter tires.
BTW Gasjs, how is the condition of roads in Latvia?
To Sigvard:
I don't know much about Estonian roads, except the distance Ainazi-Parnu-
Tallinn. The overall impression is that roads in Estonia are approx. the same or
even bit better than in Latvia.
I also wanted to go for 205/55 R16, but R17 was in GT package as standart. I'm gonna buy R16 alloys for winter but gonna use winter tyres without studs.
Fortunately I have to use gravel roads extremely rarely - 215/45 R17 are not
supposed for gravel definetely.
The diameter of the tire will affect your gas mileage to some extent. A larger diameter takes more energy to turn. If you have an engine with lots of torque, it makes less difference. Also, if you buy aftermarket wheels it may make a difference simply due to weight. Some of those bling bling wheels weigh a ton. :sarc
I agree. That's what the sales agent told me. Want to make sure since the petrol here is quite experience. Unlead Octane 95 cost US$.70 / litre.
QUOTE
Fortunately I have to use gravel roads extremely rarely.[/b]
Too bad, its a lot of fun when you have a chance to drive your car to the limit on gravel. I just cannot bear not to take a tour to some twisty country road every once in a while, just for the heck of it. However, I must admit that FWD cars are a lot less fun on gravel than RWD and can lead to very ugly situations if you're not accustomed to different driving techniques for FWD (yes, I'm speaking from experience ;))
1 - 8 of 8 Posts
