I just worked with my body shop...since they were replacing the front bumper (dang raccon), I drilled two 1.25 inch holes in the area next to the foglight (the xxxx area). I also had to drill the actually bumper face behind the foglight insert to allow clear passage of air to where the air filter is located. I initially tried drilling each of the "x" out, figured a couple larger holes would look better. I'm sure it doesn't add much, but as it's said above....it can't help.there's actually bumper behind the fog light housing. you'd need to cut out part of the bumper as well as the housing. another member has done exactly that, cut out bumper & housing and added a wire mesh.
Hey that looks good...you have a lot more patience than I did....I started and said "f" that.I did it to mine! Hears a picture. Worked just fine for me, and yes you have to cut the bumper behind the foglight assembly. No big deal! I love dremmels
Looks good. However, I'll throw this out...this will increase turbulence around the cone filter and a decrease in air flow. With the stock air inlets around the wheel wheel the air is essentially 'pushed' into the filter. That's why the lower air intake on the stock air intake resides in the same spot. Air coming in from the opposite side will decrease the effectiveness of the engineer's design and decrease air flow into the filter.
Having said this, good on you for trying something new and it does look very cool.
Hey--this si what car forums are about -- to discuss.
