I'm going to install a Sirius tuner and wanted to tap into a 12v source, and saw that many people have tapped into the cig lighter.
I searched, but could not find any post where someone specifies how exactly to tap into the source.
Should I cut the lighter plug/adapter off the end of the cable supplied with the tuner and splice into the wire that feeds the cig lighter? Does this require soldering or will wire nuts do? Is it better to go directly to a switched circuit in the fuse box?
Thanks
Thanks
