1 - 7 of 7 Posts
As most of your know that i have a fully built mazdaspeed6 and i have been working really hard to make this car a record breaker at the track while still being a daily driver. Well one of the things i really want to improve that i am closely looking at is my suspension.
I currenly have the koni yellows and megan springs. My goal is to get a 1.6 if not the 1.5s 60fts. I know that suspension plays a big part in that. The last time i went to the track i only had the megan springs and some nitto555 tires and i was able to get a 1.712 60 ft. I believe after i get this car tuned i will have the power for this. I just wanted to get your thoughts on a suspension set up that can help me out.
If you're just going in a straight line. What suspension upgrades can you do other than Coilovers on it's stiffest settings? Tons of stiffer mounts. Wider wheels/tires. Stickier tires: RE11s (or any extremes or DOT tires) for daily/track and some drag radial tires just for the drag.
there are afew vids of a members car on here showing how much better his car luanched with the hks coilovers
i think you can still find them on youtube
the BC CO's have the stiffest spring rate i think of any offered and on full stiff the car just lunges forward. i havent been to the track yet with my BT (but am itching to go REALLY soon) but when i had my SST with goobs of low end torque they def helped. the megan springs are soft as shit so i would def go the CO route. or maby get those air cylinder things u stick inside your spring to basically keep it from compressing. some MS3 guy on MSF has them. i also have yet to loose 4 wheel traction at the track being its so sticky, even on all seasons. i do however slip in the street.
For drag I alway thought the way people went was soft spring rates with low compression damping and moderate rebound damping. In the fronts, stiff is fine, but I think soft in the rear is better for weight transfer and hooking up.
Anything but the Megan springs.
I'm just throwing this out there for brainstorming, but since we can only get 50/50 power front to rear would you want setup that keeps the weight (when launching) as equal as possible over all four tires? I'm thinking a stiffer setup would be best for us then.
Also, more power would help as well as a good track surface. Not very many tuned GTR's are getting 1.5's.
i drag race a 10 second Mustang and run soft springs up front for weight transfer to the rear tires. i run stock rear springs with adj shocks, but no it idea what works for AWD. I have 1.49-1.55 60's and its all due to slicks. tires are the biggest factor
1 - 7 of 7 Posts
