1 - 8 of 8 Posts
I just sent my Scanguage II to be upgraded to the newest revision.
I know that it's capable of displaying tranny temp, torque @ converter, and HP @ crank.
But these may not work with the 6, and I haven't read anything here about people using them.
Can anyone with the latest Scanguage II tell me what new stuff they are able to display?
Trans temp doesn't work with the 6
But if you didn't have the Xgauge capability before you can take any trip display and make that a gauge. I made MPG for this trip (since the car was turned on) a gauge output.
Thanks for the info. A gauge for trip mileage would be useful, but with 3 slots being used for FIA, FWT, VLT, I was hoping to use the 4th for tranny temp. Right now I just cycle through MPG, TPS, LOD, or IGN because I really don't care about those other readings.
Did you try messing around with the Ford codes to get tranny temps?
Just a little but I had no luck. I tried e-mailing Mazda because I had good luck getting filter dimensions to size a Hydroshield but they didn't escalate it as I would have hoped.
You'll probably have to get a Lotek and get some real gauges to get the good stuff like oil temp, oil pressure, and trans temp.
The ScanGaugeII will read Transmission Fluid Temperature (TFT) on the 5-speed (JA5A-EL) transmission in Fahrenheit. I am using version 3.17 with the following XGauge parameters.
  • TXD = 07E12217B3
  • RXF = 0462051706B3
  • RXD = 3008
  • MTH = 002A0019FFC7
I am still waiting to hear back from ScanGauge about the Oil pressure.
What I need to know the answer is a list of PID's. I am guessing the oil is just an on/off type things but a guy can be hopeful.
No problem @bulwnkl .
Recently had to install a sandwich plate on my oil filter to accommodate a pressure sender. The original sender failed video and would not unscrew from the block as it was stripped. Rather than have to pull the whole thing I decided to circumvent, and had the plate tapped for an adapter that allowed me to use an OEM oil pressure switch. It solved the problem and now allows me a place to insert other items.
At one time Ortiz made custom gauge pods that integrated with the instrument cluster. A bit pricey but has the factory appearance. A much cheaper A-pillar mount would do the same thing more conspicuously.
1 - 8 of 8 Posts
