The water pump belt on the driver side is easy, Just pull the tensioner back and the belt will pop right off.
This might help you for the passenger side timing belt. It's easier to initially install the belt from the top, then route it from the bottom. It's not as hard as it looks, just pay attention to the belt routing. The hardest part is keeping the tensioner loose while doing the replacement.
