1 - 20 of 20 Posts
this evening i had four people in my car. 2 in back and 2 in front. and when i would turn a corner or go over a dip in the road the left rear tire would rub on the fender. there is actually rubber scrapings on the fender. the load i was carrying was not unusualy heavy!
anyone experienced this? i have stock 17's on the car .
Reading Topic: back tire rubbing? suspension problem?
No problems here, and I've loaded five adults into the car and flicked it through a turn pretty hard (trying to beat a traffic light). Looking at the wheel wells, I'd say it'd be impossible for them to rub... is the liner coming loose inside your wheel well?
no, the wheel wells or liners are not loose. figure this one?
I've had my 6 loaded up with 4 200+ pound males and had no problems what so ever. I'd go and have the dealer check it out.
No Probs with Mine either.....with PPL loaded etc..
You could have a possible suspension problem...
Could be a rebound issue..
Replying to Topic 'back tire rubbing? suspension problem?'
nope i don't have that problem although i do have a right rear suspension problem it hink
going at medium high spped...i don't hear it but going over say a speed bump or bumps on road at low speed, my suspension rattles.
No problem here either. Have had 5 adults in the car for extended periods of out-of-town driving and never had a problem with the suspension. Sucked a heap of fuel though.
I'd get it checked out.
wonder if it has anything to do with the new wheels that i had put on?
got konig septors put on. i will probably call the dealer soon. it doesnt do the rubbing when there is no one in the back.
Ha- well duh! You said you had the stock 17's! Wheels with the normal 40mm offset will surely rub.
Discussion Starter #10
ok, so i forgot to mention one slight little detail, about having new wheels, i thought about it but then quickly thought against it.
guess i answered my own question!
Discussion Starter #12
lets just ask one small quick question..... are YOU perfect?
i have the same prob.... shit is pissin me off. so i'm gonna roll my fenders soon whenever i get new tires. i saw a fender roller sumwur. anyone see any around?
Discussion Starter #14
And this is because you also have aftermarket wheels?
I rolled my wheelwells up and that helped alot. I still can't drive it hard fully loaded, but can with a passenger.Can't wait for the gas adjustable shocks to come out.
Discussion Starter #17
Reading Topic: Reading Topic: back tire rubbing? suspension problem?
well it is good to see that others with non stock wheels are having the same difficulties! not that it is a good thing, but that it is not just my car that has the problem. it is not often i take lots of passengers anyway, i will just do what you said shawn920 and not drive it hard when i have passengers in the back.
how much do you suppose the gas adjustable shocks will cost?
gas adjustable suspension as in fast and the furious movie? well i think that cost heaps...last time my friend installed it in his Audi and it cost him A$8K (stock+fitted)
if it's cheap i'd see heaps of ppl using it on the road. but i've seen none...except in illegal drag race.
i used my 6 to move my stuff from my old house to the new one..was loaded with heaps of stuff...presumably 500kg but it didn't rub the fenders though...
QUOTE
Originally posted by Shawn920
            I rolled my wheelwells up and that helped alot. I still can't drive it hard fully loaded, but can with a passenger.Can't wait for the gas adjustable shocks to come out.[/b]
Just wanted to know, how you rolled your wheelwells? With what, how much, and what insturctions if you don't mind. Thanks
1 - 20 of 20 Posts
