I know both are a marked improvement over stock but I want to limit the vibration at idle as much as possible. Anyone actually ridden/sat in cars with both for a direct comparison. Which provides the least vibration at idle, CP-E or AWR.
Much appreciated.
Much appreciated. [/b]
I can't say that I have sat in a Speed 6 with either of those, but from what I've seen in my research, the AWR is the stiffest because it uses poly, while the CP-E uses tougher than stock EPDM rubber, but softer than poly... In the threads I've seen, the AWR adds the most vibration since it's a "competition" mount, while the CP-E is a "street" unit...
I hope this helps!
Is the StreetUnit product about the same as the CP-E one?
Wayne
as far as the claims go, in order of stiffest to better then stock- 1)awr 2) streetunit 3) cpe. its also the order of least to most expensive
