1 - 20 of 32 Posts
So I got them Wednesday and put them on today. I have a little over an inch drop right now and it looks pretty good. I rub like crazy with the 235's on it, so it's time to roll the fenders. I took some pics of the autoEXE's next to the stockers, I'll post them up later tonight.
The ride doesn't really feel any different then before, which is nice. Overall I like them so far and will like them better when I quit cutting into my tire.
Wiggum---how are yours not rubbing if my setup matches yours? I have the 235's on RX-8 wheels.
http://www.msprotege.com/vbb225/attachment...achmentid=90272
http://www.msprotege.com/vbb225/attachment...achmentid=90273
Take a picture...
Not sure, I use Falken Azenis ST115's... but not all tires with the same sizing are actually the same size...
You are rubbing without any weight in the trunk?
Nothing in the trunk, just my big ass in the car.
The install was pretty cake, the rear took about an hour start to finish and the front was about 2-3 hours because I had to go get a spring compressor. When I got it, the actual time to take the strut and replace the spring was maybe a half an hour.
I'll get pics of the car later when I clean it all up. I have about 2" of wheel well, maybe a little less.
I have a 3 finger gap in the front and 2 finger gap in the rear......so those of you considering these, go out and finger your gap and you'll see how much it will decrease.
They're both red, it was just the lighting. I have been meaning to get some pics of the car, but I have been busy. I'll try tonight.
How much weight are you putting in the back to compress those springs enough to rub?
The rear spring rate is so high I am having a hard time getting my car to rub...
And BTW, what are your impressions of the springs so far?
Discussion Starter #10
I have nothing in the back of my car, except the spare tire. I saw in another thread that the falkens have a narrower tread area then most. I am running BFG's, so maybe they are wider. I'm cool now, I bought a fender roller and took care of it.
I really like the springs, the ride is closer to stock then any other springs I have ever felt. You can feel the stiffness more when you launch but the bumps are cake. I definatly am not mad that I spent $400 because it was money well spent to get the right springs for the car.
Just do it - ordered mine the other day. Shipment arrives 10/27 - they had 8 left when I called earlier this week.
Just wishing there was a verified shock replacement available - I would like to replace springs/shocks at the same time.
Discussion Starter #14
It's well worth the extra money to get springs designed FOR the car. I can't believe I even have springs on....until I scrape the plastic piece under the front end when I pull out of my driveway.
Sorry to hijack-I just ordered mine today! I spoke to Derrick from Corksport and he just received a shipment and the springs are in the process of clearing customs. $447.00 shipped to Sac Town via UPS. They may arrive Tuesday! Thanks for the quick review. It helped make up my mind.
Shocks will follow since I couldn't afford it all at once.
Got an email from Corksport today saying that my springs will ship tomorrow.
Just got my RX-8 wheels and Potenza RE-01R's mounted today and am looking forward to losing the gap - not to mention stiffening things up a bit.
Wanting shocks but it seems that there isn't a real consensus on what works best. There's the Koni's but I haven't heard any feedback on how they work with that setup.
Question for those that have the Autoexe springs installed - is it necessary to cut the bump stops front/rear to accomodate the decrease in suspension travel? I was looking at the bump stops today when they were mounting the wheels/tires and those things are huge.
Thanks for all your positive replies.
BUMP
Springs show up Wednesday.
I saw a post from somebody asking Wiggum about trimming bump stops.
Any insight? Good/Bad?
Thanks.
Discussion Starter #18
BUMP
Thanks.
I did not trim anything when I put mine on and I have no issues.
has it settled any lower than the original pics?
Discussion Starter #20
It still looks the same to me, but I haven't measured it.
1 - 20 of 32 Posts
