If it shows Intake Boost Air Temp, then I'm in.
I can't guarantee it will with the standard.... but with the Mazda specific, you get....
Enhanced Mazda Module List
Systems Sensors
Supported Systems
4x4 Control CAN Anti-Lock Brakes
Anti-Lock Brakes CAN Electronical Power Steering CAN
Enhanced Powertrain Enhanced Powertrain CAN
Instrument Cluster CAN Remote Keyless Entry CAN
Restraint Control Module Tire Pressure Monitor CAN
Transmission Control Module CAN
Enhanced4x4CAN
4WD Clutch PWM Status Battery Voltage
Brake On/Off Clockwise Shift Motor Driver Output State
Continuous Codes Counterclockwise Shift Motor Driver Output State
Diagnostic Trouble Codes Driver Door Ajar Switch Status
Ignition - Volts Left Front Wheel Speed
Left Rear Wheel Speed Missing The CAN Message From The ABS
Missing The CAN Message From The PCM Neutral Safety Switch
Neutral Tow Function Neutral Tow Light
Right Front Wheel Speed Right Rear Wheel Speed
Traction Control System Transfer Case Contact Plate Switch A
Transfer Case Contact Plate Switch B Transfer Case Contact Plate Switch C
Transfer Case Contact Plate Switch D Vehicle Speed
EnhancedABS
Battery Voltage Continuous Codes
Engine Speed Left Front Wheel Speed
Left Rear Wheel Speed Right Front Wheel Speed
EnhancedABSCAN
ABS Pump Motor Status
Brake Fluid Level Brake On/Off
Continuous Codes Left Front Inlet Valve State
Left Front Outlet Valve State Left Front Wheel Speed Sensor
Left Rear Inlet Valve State Left Rear Outlet Valve State
Left Rear Wheel Speed Sensor Longitudinal Accelerometer Signal
Right Front Inlet Valve State Right Front Outlet Valve State
Right Front Wheel Speed Sensor Right Rear Inlet Valve State
Right Rear Outlet Valve State Right Rear Wheel Speed Sensor
EnhancedElectronicPowerSteeringCAN
Actual Pump Motor Revolution Per Minutes Continuous Codes
Engine Speed Module Supply Voltage
Power Pack Motor Current Limit Printed Circuit Board Temperature
Pump Motor Operation Current Steering Rate Signal (filtered)
Steering Rate Signal (not Filtered) Steering Wheel Rotation Rate
System Battery Voltage Target Pump Motor Revolution Per Minutes
Temperature Sensor Supply Voltage The CAN Communication With The IC
The CAN Communication With The PCM Transistors Temperature
Vehicle Speed - Low Resolution
EnhancedInstrumentClusterCAN
Antilock Braking System Warning
Battery Voltage Brake System Warning Indicator Input Status
Continuous Codes Diagnostic Trouble Codes
Door Ajar Warning Indicator Driver Buckle Switch Status
Driver Door Ajar Switch Status Engine Temperature Gauge
Fuel Level Headlamp Switch Status
Ignition Key In / Out Low Fuel Warning Indication
Number Of Keys Stored In Module Odometer Rolling Count
Oil Pressure Warning Lamp Passenger Door Ajar Switch Status
Safety Belt Warning Lamp Speedometer
Tachometer The CAN Communication With The RKE
The CAN Communication With The TPM Total Distance
Trip / Odometer Button
EnhancedPowertrain
# Of Ignition Key Codes Stored
# Of Keys # Of OBDII Drive Cycles Completed
# Of Test Fault Codes A/C Head Pressure
A/C Head Pressure - PSI A/C Head Pressure - Volts
A/C Load Signal Volts AC ET
AC RT Adaptive Memory Status
Air Condition Cycle Switch Air Ride Control Fault
Alternator Control Field Output Duty Alternator Voltage
Anti-Scan Function Average Calibration Test Freq B1
Average Calibration Test Freq B2 Barometric Pressure
Barometric Pressure - Volts Barometric Pressure Sensor
Barometric Pressure Sensor Barometric Pressure Sensor - Hz
Barometric Pressure Sensor - Volts Battery Voltage
Blower Motor Brake Switch
Break Pedal Switch Calculated Engine Load
Calculated Load CCL_ON
CFCILF Closed Loop Fuel Status
Closed Loop Fuel Status Clutch Engaged
Clutch Pedal Position Coast Clutch Solenoid 2/3 Timing
Coast Clutch Solenoid Fault Coast Clutch Solenoid Pressure
Coast Clutch Solenoid Primary CKT Monitor Commanded Duty Cycle
Commanded Idle Air Control Commanded Transmission Gear
Continuous Codes Cylinder Head Temperature - Volts
Cylinder Head Temperature Lamp Cylinder Head Temperature Lamp Fault
Daytime Running Lamp Input Defroster Switch
DPFEGR EGR
EGR Boost Solenoid Control EGR Boost Solenoid Control - Volts
EGR Enable Baro EGR Fault Open Circuit
EGR Fault Short Circuit EGR Fault Vent Solenoid
EGR Solenoid Vacuum Duty Value EGR Solenoid Vent Duty Value
EGR Step Motor 1 EGR Step Motor 2
EGR Step Motor 3 EGR Step Motor 4
EGR Vacuum Regulator EGR Vacuum Solenoid
EGR Vacuum Solenoid Fault EGR Valve Position
EGR Valve Position Control - Volts EGR Vent Solenoid
EGRMDSD Engine Coolant Temperature
Engine Coolant Temperature Engine Coolant Temperature
Engine Coolant Temperature - Volts Engine Coolant Temperature - Volts
Engine Fuel Temperature Bank 1 - Volts Engine Fuel Temperature Bank 2 - Volts
Engine Misfire Counter Engine Misfire Status
Engine Oil Temperature Fault Engine Speed
EPC Transmission Shift - Volts EPC Transmission Shift Command
EVAP Emission Canister Purge EVAP Emission Canister Purge Dc
EVAP Emission Canister Purge Fault EVAP Emission Canister Purge Vent Dc
EVAP Emission Canister Purge Vent Fault EVAP Vapor Management Valve
Fan Secondary Circuit Monitor Feedback Fuel Control Status
Flex Fuel Sensor Flex Fuel Sensor Frequency
FP GND/SIG Ret Difference Front Heated O2 Sensor Left
Front Heated O2 Sensor Volt Right FSS
Fuel Injector Duration Left Fuel Injector Duration Right
Fuel Level Input Fuel Level Input - Volts
Fuel Pressure Control Valve Fuel Pump Control Primary Circuit
Fuel Pump Duty Cycle Fuel Pump Monitor
Fuel Pump Monitor Fuel Pump Monitor Dc
Fuel Pump Output Fault Fuel Rail Pressure
Fuel Rail Pressure - Volts Fuel Solenoid
Fuel Solenoid Fault Fuel Solenoid Valve
Fuel Tank Level Fuel Tank Pressure - Volts
Fuel Tank Pressure - Volts Fuel Tank Pressure Purge Monitor
Generator Field Control Output GFS
Headlamp Input Headlight Switch
High Speed Fan High Speed Fan Output Fault
High Speed Fan Primary Circuit Idle Air Control Output Fault
Idle Air Control Valve Ignition Switch
Ignition Timing Ignition Timing
Ignition Timing Advance Cylinder 1 Injector #1 Output Fault
Injector #10 Output Fault Injector #2 Output Fault
Injector #3 Output Fault Injector #4 Output Fault
Injector #5 Output Fault Injector #6 Output Fault
Injector #7 Output Fault Injector #8 Output Fault
Injector Pulse Width Injector Pulse Width
Injector Pulse Width Bank 1 Injector Pulse Width Bank 2
Intake Air Temperature Intake Air Temperature
Intake Air Temperature Intake Air Temperature - Volts
Intake Air Temperature - Volts Intake Manifold Run Continuous Fault
Intake Manifold Run Continuous Input B1 Intake Manifold Run Continuous Input B2
Intake Manifold Run Control Intake Manifold Run Control Monitor
Intake Manifold Tuning Valve Continuous Intake Manifold Tuning Valve Control
Knock Sensor Test Knocking Retard
Long Term Fuel Trim Bank 1 Long Term Fuel Trim Bank 1
Long Term Fuel Trim Bank 1 Long Term Fuel Trim Bank 2
Long Term Fuel Trim Bank 2 Low Speed Fan Control
Low Speed Fan Output Fault Low Speed Fan Primary Circuit
Low Speed Pump Fault LPG FLI
MAF Signal Voltage Malfunction Indicator Lamp
Manifold Absolute Pressure Manifold Absolute Pressure
Manifold Absolute Pressure - Volts Manifold Absolute Pressure - Volts
Mass Air Flow Rate Mass Air Flow Rate - Volts
Master Key Present MIL Out Fault
Misfire Wheel Profile Learned MSF_FLG
O2S Downstream Heater Control O2S Heater Bank 1 Downstream
O2S Heater Bank 1 Downstream Out Fault O2S Heater Bank 1 Downstream Primary
O2S Heater Bank 1 Upstream O2S Heater Bank 1 Upstream Out Fault
O2S Heater Bank 1 Upstream Primary O2S Heater Bank 2 Downstream
O2S Heater Bank 2 Downstream Out Fault O2S Heater Bank 2 Downstream Primary
O2S Heater Bank 2 Upstream O2S Heater Bank 2 Upstream Out Fault
O2S Heater Bank 2 Upstream Primary O2S Upstream Heater Control
Oxygen Sensor Bank 1 Upstream Power Steering Pressure Switch
Purge Flow Sensor Purge Solenoid Duty Value
Rear Heated O2 Sensor Left Rear Heated O2 Sensor Voltage Right
Secondary Air Bypass Secondary Air Bypass Solenoid Monitor
Secondary Air Commanded On Secondary Air Divert
Secondary Air Fault Indicator Secondary Air Monitor
Secondary Air Primary CKT Monitor Security Access
Short Term Fuel Trim Bank 1 Short Term Fuel Trim Bank 2
Swirl Valve Target Engine Speed
Test Frequency B1 Test Frequency B2
Throttle Position Sensor Signal Voltage Time Since Start
Transmission Range Switch Vehicle Enable Status
Vehicle Speed
EnhancedPowertrainCAN
A/C Request Signal
Accelerator Pedal Position Accelerator Pedal Position 1
Accelerator Pedal Position 1 - Volts Accelerator Pedal Position 2
Accelerator Pedal Position 2 - Volts Actual AFR
Actual Valve Timing Actual Valve Timing 2
Air Conditioning Clutch Air Conditioning Compressor Cycling Switch
Air Conditioning Compressor Cycling Switch Air Fuel Ratio
Ambient Air Temperature At Time Of Misfire: EGR Sensor Input
At Time Of Misfire: Engine Load At Time Of Misfire: Engine RPM
At Time Of Misfire: Engine Running Time At Time Of Misfire: Intake Air Temperature
At Time Of Misfire: Park/Neutral Position At Time Of Misfire: Throttle Position - Volts
At Time Of Misfire: Vehicle Speed BARO/SEGRP Solenoid
Barometric Pressure Barometric Pressure - Hz
Barometric Pressure - Vacuum Barometric Pressure - Volts
Battery Voltage Battery Voltage
Boost Air Temperature Sensor Boost Air Temperature Sensor - Volts
Brake On/Off Brake Pressure Applied Switch
Camshaft Position Commanded Duty Cycle 1 Camshaft Position Commanded Duty Cycle 2
Camshaft Position Sensor Status Clutch Pedal Position Switch/neutral Switch Circuit
CMP And CKP Synchronized Continuous Codes
Converter Pressure Control Cylinder Head Temperature
Cylinder Head Temperature Cylinder Head Temperature - Volts
Cylinder Head Temperature Indicator Lamp Cylinder Head Temperature Status
Delta Feedback Pressure Exhaust Gas Recirculation Desired Equivalence Ratio
Desired Idle Speed Desired RPM
Desired SEGRP Valve Position Diagnostic Trouble Codes
Difference Between Target And Actual Valve Timing Difference Between Target And Actual Valve Timing 2
Distance Since Diagnostic Trouble Codes Cleared EGR Motor Control 1
EGR Motor Control 2 EGR Motor Control 3
EGR Motor Control 4 Electronic Throttle Control Actual
Electronic Throttle Control Desired Electronic Throttle Control Desired - Deg
Engine Coolant Temperature Engine Coolant Temperature - Volts
Engine Coolant Temperature Status Engine Load
Engine Load Engine Off Soak Time Prior To Misfire
Engine Speed Engine Speed
Equivalence Ratio EVAP Control System Incorrect Purge Flow Detection Valve
EVAP Control System Small Leak Detection Valve EVAP Control System Very Small Leak - Fail Value
EVAP Control System Very Small Leak - Safe Value EVAP Control System Very Small Leak Detection Valve
EVAP System Leak Detection Pump Idle Current EVAP System Leak Detection Pump Monitoring Current
EVAP System Leak Detection Pump Reference Current Evaporative Emission Canister Purge Fault
Evaporative Emission Canister Purge Valve Duty Cycle Evaporative Emission Canister Vent Valve
Evaporative Emission Vapor Management Fault Evaporative Emission Vapor Management Valve
Evaporative Emission Vapor Management Valve Exhaust Gas Recirculation Status
Exhaust Gas Recirculation Valve Duty Cycle Fan 1 Control Signal
Fan 2 Control Signal Fan 3 Control Signal
Fan Control High Fault Fan Control High Speed
Fan Control Low Fault Fan Control Low Speed
Fuel Cap Off Indicator Lamp Fuel Injection Amount
Fuel Level Fuel Level
Fuel Pressure Sensor Fuel Pulse Width
Fuel Pulse Width #1 Fuel Pulse Width #2
Fuel Pump Fuel Pump
Fuel Pump Monitor Fuel Rail Pressure
Fuel Rail Pressure - Volts Fuel Rail Pressure Desired
Fuel Rail Pressure Transducer Status Fuel Rail Temperature
Fuel Rail Temperature - Volts Fuel Tank Pressure Transducer
Fuel Tank Pressure Transducer - Volts Fuel Tank Pressure Transducer Status
Gear Ratio Generator Field Current Control Duty Signal
Generator Field Duty Cycle Generator Lamp Circuit
Generator Monitor Generator Output Fault
Generator Output Voltage Generator Voltage Desired
Generator Warning Light Heated Exhaust Gas Oxygen Sensor B1S1
Heated Exhaust Gas Oxygen Sensor B1S1 Heated Exhaust Gas Oxygen Sensor B1S1
Heated Exhaust Gas Oxygen Sensor B1S1 Heated Exhaust Gas Oxygen Sensor B1S1 - Status
Heated Exhaust Gas Oxygen Sensor B1S2 Heated Exhaust Gas Oxygen Sensor B1S2
Heated Exhaust Gas Oxygen Sensor B1S2 - Status Heated Exhaust Gas Oxygen Sensor B1S3
Heated Exhaust Gas Oxygen Sensor B1S3 Heated Exhaust Gas Oxygen Sensor B1S3 - Status
Heated Exhaust Gas Oxygen Sensor B2S1 Heated Exhaust Gas Oxygen Sensor B2S1
Heated Exhaust Gas Oxygen Sensor B2S1 - Status Heated Exhaust Gas Oxygen Sensor B2S2
Heated Exhaust Gas Oxygen Sensor B2S2 Heated Exhaust Gas Oxygen Sensor B2S2
Heated Exhaust Gas Oxygen Sensor B2S2 Heated Exhaust Gas Oxygen Sensor B2S2 - Status
Heated Exhaust Gas Oxygen Sensor B2S3 Heated Exhaust Gas Oxygen Sensor B2S3 - Status
Heated Exhaust Oxygen Sensor B1S1 - Status Heated Exhaust Oxygen Sensor B2S1 - Status
Heater Control For O2s B1S1 Fault Heater Control For O2s B1S2 Fault
Heater Control For O2s B2S1 Fault Heater Control For O2s B2S2 Fault
Heater Current Monitor For Heated Exhaust Oxygen Sensor B1S1 Heater Current Monitor For Heated Exhaust Oxygen Sensor B1S2
Heater Current Monitor For Heated Exhaust Oxygen Sensor B2S1 Heater Current Monitor For Heated Exhaust Oxygen Sensor B2S2
High Pressure Fuel Pump - Status Idle Air Control
Idle Validation Switch IMTV Status
In Gear - Status Injector 1 Fault
Injector 2 Fault Injector 3 Fault
Injector 4 Fault Injector 5 Fault
Injector 6 Fault Inlet Air Temperature Status
Input Shaft Speed Intake Air Shutter Valve - Status
Intake Manifold Runner Control Intake Manifold Tuning Valve
Intake Manifold Tuning Valve Keep Alive Memory Power
Knocking Retard Lambda Sensor Computer Modification - Status
Lean-to-Rich Delayed Time Lean-to-Rich Slow Response Time
Learned Misfire Correction Profile - Status Line Pressure Control
Long Term Fuel Trim 1 Long Term Fuel Trim 1
Long Term Fuel Trim 2 Long Term Fuel Trim 2
Lowest Closed Throttle Voltage Malfunction Indicator Lamp - Status
Manifold Absolute Pressure - Volts Manifold Absolute Pressure Sensor
Mass Air Flow Mass Air Flow
Mass Air Flow - Volts Mass Air Flow - Volts
Mass Air Flow Status Medium Fan Control
Medium Fan Control Status Misfire Malfunction Detection
Module Supply Voltage Module Supply Voltage
Net Engine Torque Number Of Keys Stored In Module
Number Of On Board Diagnostic Trips Completed Number Of Trips Since The Time Of Misfire
Number Of Warm-ups Since DTCs Cleared On-Board Diagnostic Trip Completed - Status
Output Shaft Speed Output Shaft Speed Failure Mode
Output Shaft Speed Reliable - Status Overdrive Cancel Switch/Hold Switch
PCM Control Relay - Status Power Steering Pressure Switch - Status
Pressure Control Failure Mode - Status Pressure Control Solenoid A
Pressure Control Solenoid A Pressure Control Solenoid B
Pressure Control Solenoid B Refrigerant Pressure Switch
Relative Throttle Position Rich-to-Lean Delayed Time
Rich-to-Lean Slow Response Time Shift RPM Drop In Input Shaft Speed Below Expected
Shift RPM Rise In Input Shaft Speed Above Expected Shift Solenoid 1
Shift Solenoid 1 Status Shift Solenoid 2
Shift Solenoid 2 Status Shift Solenoid 3
Shift Solenoid 3 Status Shift Solenoid Pressure Control B
Shift Time Elapsed From 10% To 90% Of Complete Shift Time Elapsed From Commanded To 10% Complete
Shift Type Short Term Fuel Trim 1
Short Term Fuel Trim 1 Short Term Fuel Trim 2
Short Term Fuel Trim 2 Short Term Fuel Trim B1S1
Short Term Fuel Trim B1S2 Short Term Fuel Trim B1S3
Short Term Fuel Trim B2S1 Short Term Fuel Trim B2S2
Spark Advance Spark Advance
Speed Control Actuator Switch On Speed Control Command Switch - Volts
Speed Control Set Indicator TEN Terminal
The Distance Traveled Since The Mil Was Activated Throttle Position - Volts
Throttle Position 1 Throttle Position 1 - Volts
Throttle Position 2 Throttle Position 2 - Volts
Throttle Position Sensor Status Time Since Start (s)
Tire Size Torque Converter Clutch
Torque Converter Clutch Fault Torque Converter Slip Actual
Torque Converter Slip Desired Total Number Of Misfires
Transmission Control Indicator Light Transmission Control Indicator Light
Transmission Fluid Temperature Transmission Fluid Temperature - Volts
Transmission Fluid Temperature Status Transmission Gear Ratio
Transmission Over Temperature Transmission Over Temperature Lockup Mode
Transmission Range - Volts Transmission Range Status
Transmission Slip Ratio Turbine Shaft Speed
Turbine Shaft Speed Reliable Turbine Speed Sensor Failure Mode
Unfiltered Output Shaft Speed A Unfiltered Turbine Shaft Speed
Valid Drive Counter Variable Fan Duty Cycle
Variable Tumble Control Solenoid Valve Variable Valve Timing Advance For The Computer Modification
Variable Valve Timing Computer Modification Vehicle Speed
Vehicle Speed Vehicle Speed Sensor Reliable
Vehicle Speed Sensor Signal Status WGC Solenoid Valve
Wide Open Throttle A/C Cut-off Fault
EnhancedRemoteKeylessEntryCAN
Accessory (acc) Power
Brake On/Off Central Locking Switch - Lock
Central Locking Switch - Unlock Continuous Codes
Door Switch - All Door Switch - Driver Side
Driver Side Door Lock Link Switch Engine Speed
Hood Switch Ignition 1 Power
Ignition Key In Key Cylinder Immobilizer Function (On = Supported)
Key Cylinder Switch - Lock Key Cylinder Switch - Unlock
Module Supply Voltage Number Of Card Keys Registered In Module
Number Of Keys Registered In Module Outer Buzzer
Passenger Side Door Lock Link Switch Request Switch - Driver Door
Request Switch - Passenger Door Request Switch - Trunk/Lift Gate
Security Indicator Lamp Trunk/Lift Gate Switch
EnhancedRestraintControlModule
Continuous Codes
Driver Curtain Driver Side Airbag Module Resistance
Driver Side Impact Air Bag Resistance Ignition - Volts
Passenger Air Bag Passenger Retractor Circuit Resistance
Passenger Side Air Bag #2 Resistance Passenger Side Impact Air Bag Resistance
Pretension Circuit Resistance, Driver Side Side Airbags Safety Curtain
EnhancedRestraintControlModuleCAN
Air Bag Circuit Open - Loop No. 1, Front Driver Side Air Bag Circuit Open - Loop No. 1, Front Driver Side
Air Bag Circuit Open - Loop No. 1, Front Passenger Side Air Bag Circuit Open - Loop No. 1, Front Passenger Side
Air Bag Circuit Open - Loop No. 2, Front Driver Side Air Bag Circuit Open - Loop No. 2, Front Driver Side
Air Bag Circuit Open - Loop No. 2, Front Passenger Side Air Bag Circuit Open - Loop No. 2, Front Passenger Side
Air Bag Circuit Short To Battery - Loop No. 1, Front Driver Side Air Bag Circuit Short To Battery - Loop No. 1, Front Driver Side
Air Bag Circuit Short To Battery - Loop No. 1, Front Passenger Side Air Bag Circuit Short To Battery - Loop No. 1, Front Passenger Side
Air Bag Circuit Short To Battery - Loop No. 2, Front Driver Side Air Bag Circuit Short To Battery - Loop No. 2, Front Driver Side
Air Bag Circuit Short To Battery - Loop No. 2, Front Passenger Side Air Bag Circuit Short To Battery - Loop No. 2, Front Passenger Side
Air Bag Circuit Short To Ground - Loop No. 1, Front Driver Side Air Bag Circuit Short To Ground - Loop No. 1, Front Driver Side
Air Bag Circuit Short To Ground - Loop No. 1, Front Passenger Side Air Bag Circuit Short To Ground - Loop No. 1, Front Passenger Side
Air Bag Circuit Short To Ground - Loop No. 2, Front Driver Side Air Bag Circuit Short To Ground - Loop No. 2, Front Driver Side
Air Bag Circuit Short To Ground - Loop No. 2, Front Passenger Side Air Bag Circuit Short To Ground - Loop No. 2, Front Passenger Side
Air Bag Inflator Circuit Resistance Low - Loop No. 1, Front Driver Side Air Bag Inflator Circuit Resistance Low - Loop No. 1, Front Driver Side
Air Bag Inflator Circuit Resistance Low - Loop No. 1, Front Passenger Side Air Bag Inflator Circuit Resistance Low - Loop No. 1, Front Passenger Side
Air Bag Inflator Circuit Resistance Low - Loop No. 2, Front Driver Side Air Bag Inflator Circuit Resistance Low - Loop No. 2, Front Driver Side
Air Bag Inflator Circuit Resistance Low - Loop No. 2, Front Passenger Side Air Bag Inflator Circuit Resistance Low - Loop No. 2, Front Passenger Side
Bracket Ground Resistance Continuous Codes
Driver Air Bag Driver Air Bag #2 Resistance
Driver Buckle Switch Current Measurement Driver Buckle Switch Resistance
Driver Buckle Switch Status Driver Retractor Circuit Resistance A/d Count
Driver Seat Track Current Measurement Driver Side Airbag Module Resistance
Driver Side Impact Air Bag Resistance External Crash Sensor Test Voltage
Front Crash Sensor Internal Fault Front Crash Sensor Internal Fault
Front Crash Sensor Mount Or Communication Fault Front Crash Sensor Mount Or Communication Fault
Front Crash Sensor Mount/Communication Fault Front Driver Airbag Curtain Resistance
Front Passenger Airbag Curtain Resistance Front Passenger Side Belt Tension Sensor Circuit Fault
Front Passenger Side Belt Tension Sensor Circuit Fault Front Passenger Side Belt Tension Sensor Short To Ground
Front Passenger Side Belt Tension Sensor Short To Ground Generic OCS Module Fault, Front Passenger Side
Generic OCS Module Fault, Front Passenger Side Generic OCS Module Fault, Front Passenger Side
Ignition Voltage OCS Calibration Fault, Front Passenger Side
OCS Calibration Fault, Front Passenger Side OCS Calibration Fault, Front Passenger Side
OCS Communications Fault, Front Passenger Side OCS Communications Fault, Front Passenger Side
OCS Communications Fault, Front Passenger Side OCS Measured Weight Of Passenger
OCS Sensing Element Fault, Front Passenger Side OCS Sensing Element Fault, Front Passenger Side
OCS Sensing Element Fault, Front Passenger Side, Belt Tension Sensor OCS Sensing Element Fault, Front Passenger Side, Left
OCS Sensing Element Fault, Front Passenger Side, Right On Demand Front Crash Sensor Internal Fault
On Demand Front Crash Sensor Mount/Communication Fault On Demand Side Crash Sensor Internal Fault, Front Driver
On Demand Side Crash Sensor Internal Fault, Front Passenger On Demand Side Crash Sensor Mount/Communication Fault, Front Driver
On Demand Side Crash Sensor Mount/Communication Fault, Front Passenger Passenger Air Bag
Passenger Airbag Deployment Status Passenger Buckle Switch Current Measurement
Passenger Buckle Switch Resistance Passenger Buckle Switch Status
Passenger Retractor Circuit Resistance Passenger Side Air Bag #2 Resistance
Passenger Side Airbag Module Resistance Passenger Side Impact Air Bag Resistance
Pretension Circuit Open, Front Driver Side Pretension Circuit Open, Front Driver Side
Pretension Circuit Open, Front Passenger Side Pretension Circuit Open, Front Passenger Side
Pretension Circuit Resistance Low, Front Driver Side Pretension Circuit Resistance Low, Front Driver Side
Pretension Circuit Resistance Low, Front Passenger Side Pretension Circuit Resistance Low, Front Passenger Side
Pretension Circuit Resistance, Driver Side Pretension Circuit Short To Battery, Front Driver Side
Pretension Circuit Short To Battery, Front Driver Side Pretension Circuit Short To Battery, Front Passenger Side
Pretension Circuit Short To Battery, Front Passenger Side Pretension Circuit Short To Ground, Front Driver Side
Pretension Circuit Short To Ground, Front Driver Side Pretension Circuit Short To Ground, Front Passenger Side
Pretension Circuit Short To Ground, Front Passenger Side RCM Ignition Voltage No. 2
Read Crash Recording Seat Track Position Status
Side Airbags Safety Curtain Side Airbags Safety Curtain
Side Crash Sensor Internal Fault, Front Driver Side Side Crash Sensor Internal Fault, Front Passenger Side
Side Crash Sensor Mount Or Communication Fault, Front Driver Side Side Crash Sensor Mount Or Communication Fault, Front Passenger Side
EnhancedTirePressureMonitorCAN
Last Received Tire Transmitter ID Code Value Left Front Learn Status
Left Front Low Battery Left Front Normal Status
Left Front Re-measure Status Left Front Sensor Programmed
Left Front Tire Pressure Left Front Tire Transmitter Identifier
Left Front Transmit Received After Learn Left Rear Learn Status
Left Rear Low Battery Left Rear Normal Status
Left Rear Outer Tire Pressure Left Rear Re-measure Status
Left Rear Sensor Programmed Left Rear Tire Transmitter Identifier
Left Rear Transmit Received After Learn Right Front Learn Status
Right Front Low Battery Right Front Normal Status
Right Front Re-measure Status Right Front Sensor Programmed
Right Front Tire Pressure Right Front Tire Transmitter Identifier
Right Front Transmit Received After Learn Right Rear Learn Status
Right Rear Low Battery Right Rear Normal Status
Right Rear Outer Tire Pressure Right Rear Re-measure Status
Right Rear Sensor Programmed Right Rear Tire Transmitter Identifier
Right Rear Transmit Received After Learn Spare Tire Pressure
Spare Tire Transmitter Identifier Transmitter Identifier With Warning Value 1
Transmitter Identifier With Warning Value 2 Transmitter Identifier With Warning Value 3
Transmitter Identifier With Warning Value 4 Transmitter Identifier With Warning Value 5
Wheel 1 Pressure Wheel 1 Temperature
Wheel 2 Pressure Wheel 2 Temperature
Wheel 3 Pressure Wheel 3 Pressure
Wheel 3 Temperature Wheel 3 Temperature
EnhancedTransmissionCAN
2-4 Brake Solenoid Brake Switch Input Status
Continuous Codes Downshift Switch
Engine Coolant Temperature From TCM Engine Revolutions Per Minute
Gear Ratio High Clutch Solenoid
High Temperature Mode Count Intermediate Shaft Speed
Line Pressure Solenoid Line Pressure Solenoid
Line Pressure Solenoid Line Pressure Solenoid B
Manual Range Switch Module Supply Voltage
Oil Pressure Switch B Output Shaft Speed
Output Shaft Speed Park / Neutral
Pending Code That Caused FFD Storage Shift Solenoid 1
Shift Solenoid 1 Shift Solenoid 2
Shift Solenoid 2 Shift Solenoid 3
Shift Solenoid 3 Shift Solenoid 4
Shift Solenoid A Shift Solenoid B
Shift Solenoid C Shift Solenoid C
Shift Solenoid D Shift Solenoid D
Shift Solenoid E Shift Solenoid E
Shift Solenoid E/5 Shift Solenoid F
Shift Solenoid F Shift Solenoid F6
Shift Solenoid G Steering Shift Switch - Down Switch
Steering Shift Switch - Up Switch Target Modifier Pressure
The CAN Communication With The ABS The CAN Communication With The IC
The CAN Communication With The PCM The Distance Traveled Since The High Temperature Mode Was Activated
Throttle Position Throttle Position
Torque Converter Clutch Control Solenoid Torque Converter Clutch Control Solenoid
Transmission D Range Switch Transmission Fluid Temperature
Transmission Fluid Temperature - Volts Transmission R Range Switch
Transmission Range Sensor - Volts Turbine Shaft Speed
Turbine Shaft Speed Upshift Switch
Vehicle Speed VPWR TCM - Volts
