1 - 2 of 2 Posts
hey all! this is my first post here... just traded in the 3 for a speed 6gt.. here is my question and I kinda found the answer but it wasnt very detailed...
Does anyone have a walkthrough on how to take out the radio so I can install my brandy new (used) audio link? I did see the walkthrough on the site here, but maybe i am missing something... Does anyone have any pics showing the how-to... Also any tips would be a HUGE help! Thanks all!
I just did mine.
Remove the pass side glove compartment.
Locate a 10mm (ithink) black bolt connected to the stock radio behind the compartment to the left.
Remove the cup holder by pulling
Remove shift knob and shifter trim.
Remove two small black screws holding the faceplate to the dash. Located at the bottom, black in color.
Gently pull the edges of the dash/console. You don'tneed to disconnect anything or unplug anything.
Simply run your audio link wires behind the dashfor a clean install and plug it into the empty slot behind the radio.
Put it all back together, turn car on, then off then on and test your ipod.
Very easy install.
1 - 2 of 2 Posts
