1 - 9 of 9 Posts
Ok I flushed my transmission fluid the day before yesterday. When I took the pan off I discovered that two or three of the bolts had completely stripped threads. These were on the hard to reach side (drivers side). Well I got everything finished and put on the liquid gasket stuff and tightened everything up. Well now I have discovered a leak in the pan. How did it not leak before but it does now? Help me fix this!
You have a 6i right? If so it'll be a real bitch just due to the lack of space. If so the only real fixes would be to tap to the next size or use a helicoil insert. GL
It's possible they weren't stripped from over-tightening, but that the bolt was seized into the threads and you then pulled them out. That would explain how it was tight & not leaking before, but is leaking now.
ya 6i. well the good news is that one of them is where you can see the edge of the pan so a nut could just be welded to the top and just liquid gasket the crap out of that bolt. But the others are where they go straight into it.
ya I am sure they were, when I took them out there were flakes of metal that came out and the threads didn't look right.
Tapping them wont be hard or expensive.Its the fact youd probably have to drop the subframe that complicates things.
ugh well they are going to have to drop the subframe. cost is going to be anywhere from $300-400. everytime I inspect something closely on this car its either already broken or I fuck it up somehow. Time sell for a profit and get a 2005 evo vii for 5 grand more....
1 - 9 of 9 Posts
