1 - 3 of 3 Posts
Just curious. I ordered my PIAA Super Rozza's 19x8 with +45 offset and some 245/35-19's along with the Autoexe springs. Hoping everything will work together.
Mike
if you roll the fenders and adjust the rear suspension to add as much negative camber as possible you should be fine, just don't expect your tires to last very long. I had 19x8" +45mm with 235 and I still had about 1/2" of space between the tire and the fender with full negative camber in the rear.
Also note you will need to roll the WHOLE fender not just the top.
Well as a backup plan I'll measure caliper and strut clearance and if need be shave down the back side of the hub 5mm.
Where there's a will. There's a way!
Mike
1 - 3 of 3 Posts
