1 - 2 of 2 Posts
Any one have this brake kit? If so do u like it. i noticed it was only a 2 piston, i think stock brakes are better then a 2 piston. Any advice would help. I might get the rotra big brake kit. but thats alot of money.
The stock brakes are single piston.
I assume this is the kit you're referring to? Front Force 10 2-Piston Aluminum Caliper Disc Brake Kit
I don't know anything more about this big brake kit from SSBC, but it looks like it is the fronts only. The rotors are significantly larger than stock - 13in vs. 11.1in stock (I think) so stopping power should improve significantly. However, without a complete kit for front and back you might need to consider brake bias. I don't know that it will be a problem, but definitely something you should look into.
Maybe someone who's used this kit will chime in to enlighten us...
1 - 2 of 2 Posts
