any answers??
679 Views 3 Replies 3 Participants Last post by  turbo matt
yea i installed my bov the hks one with the cpe flange that i got from the rpm store i installed it and everything works well but i have no sound??? any one know if i did something wrong or forgot something??
I assume you have not upgraded the stock air box to one of the cold-air intakes available? The stock airbox and resonator do an amazing job of silencing the turbo and BOV sounds. Unless your run the BOV in vent-to-atmosphere mode, you probably won't notice any change in sound with the stock airbox. Personally, I would recommend keeping the BOV in recirculation-mode for best engine performance.
If you don't plan to switch to an aftermarket intake, you could try the "airbox mod" that involves removing the resonator and "tuba" if you want more sound.
THANK YOU VERY MUCH
take the lower airbox out (inside the drivers side fender) remove the plate looking thing on the bottom of the airbox and take out the "Tuba" looking thing on the front of the airbox and your set.
