Ordered one of these off aliexpress, my model is by a brand called EKIY. Took almost a month to get here, wiring wasn’t too complicated. Should be plug and play if you don’t have bose. Comes with hardware and wiring for manual or auto ac. I may have read it doesn’t work for 2003-2005 auto climate. If you do have bose you need to cut your amp signal wires that go to each speaker and hook them up to rcas. You can then attach the rcas to the appropriate left/right front/back combo to the audio out rcas connection on the android unit. You will also need to do the same for the remote wire from your harness which is black/blue to your amp power wire that should be loose on the android unit. You have to attach your vents and ac control panel along with their ac control board with buttons they include with the dash kit. I was able to set up my steering controls easily after setting up the android to recognize my car by setting the canbus. It has WiFi/Bluetooth/4g if you add your own SIM card/gps and can do a plethora of functions much like an android device can. I have yet to download other apps or really explore the capabilities part listening to music or playing videos. I’m having trouble getting gps setup, not sure if I’m missing something or I’m not getting a signal. But here is the result:
