1 - 20 of 53 Posts
A MS6 update (welcome to my nightmare)
I haven't posted on here in forever and MarineMazda said i should share. Seeing as this is a small group i am confidant that some of you already know about this.
Well my MS6 died so i thought i would share the repairing of a timing chain on a VVT
first i cleaned the engine bay
Then i started to take it apart.
Is that oil in the intercooler.... Ah stupid PCV valve...
that carbon is from the freash air inlet to the crankcase... shouldn't the air be going in not out?...
Day two,
EGR tube
EGR tube Plus something... ;)
Chain left scars
Overall it was nice and clean in there
Discussion Starter #2
Update,
Little wear for 103k on the motor.
what died next to the new one
that isn't shipped as a slot
where they heat treated the part so that it lasts more then 100k
ford doesn't believe in keyways, no instead for those that haven't seen it let me introduce the "friction washer".... Also nothing is a press fit.
stretched chain
primer
krinkle paint
After i was done i started the car and it sounded like a tin full of mables. After digging through the whole motor i found this
Anyway here are some interesting pics i took...
I can say this because of were i work, but the only castings that get hand scribed are prototypes and they are not for public sale. So WTF
Just a nice pic i think. Good colours and focal depth.
Direct injection for the fail here
So yeah that is were i am now, I am going to order cp pistons k1 rods, cp-e injector seals, pump internals, and hope that things go better this time.
I have to say that the oiling system in this block is great! i have never seem mains that looked this good with 100km on them.
Major kodos for finding the bent rod before things got worse. Best wishes to get the car running again.
Thanks for all the pics and GL with the build.
Lowspeed
Hate your having to go through all this!
Good Luck on your build, and thanks for taking us along on your ride rebuild
Keep the pics coming :thumbup:
That stretched chain is kind of amazing, you would never think that metal could warp and stretch like that. Thanks for the pics and good luck with the re-build.
Great step by step and what you have done. Im getting my VVT replaced today, hopefully my chain and valve cover are still in good shape. However I did drive my car for awhile with a broken VVT (dumb move).
Agreed thanks for the Step by step also. Thanks
I can't wait for the end results.....GL with your build.
I have to start going through my motor the same way this weekend. Making a pretty nasty knocking noise. Im afraid its a bent rod, or spun bearing, or worse. (Is there worse?)
Anyways, nice pics, and thank you! Gives me an idea of what to look for while im rooting around in there!
Discussion Starter #15
Well i have ordered CP pistons and K1 rods. I hope to get the block to the machine shop next week. Well i was odering stuff i got the CP-e injector seals as well.
Lowspeed
Nifty collection of shiny bits :thumbup:
sdit to add- Keep up with the pics! Love to see more pics of the build as you go!
Discussion Starter #18
update
made this
And did this
The head is also done and ready to go. I still need to file the ring and i hope to be putting a motor back in this car this coming weekend.
what did you machine on the end of the block ?
1 - 20 of 53 Posts
