1 - 3 of 3 Posts
you should read the instructions that came with the amp, if none came with it, look for a manual/guide online.
Some amps don't require an remote wire if using high level inputs, some do.
Mount your ground to the rear seat bolts.
Run the remote line from the amp to any 12V ACC wire. (i.e. Cigarette Lighter, or anything that comes on when the key is in the acc position)
1 - 3 of 3 Posts
