21 - 36 of 36 Posts
I don't have the PAC AOEM-MAZ2 yet, but today i have run the power from the battery to the trunk.
Here's what i found under the hood :)
So no need for an additional ugly fuse :)
I have pass the wire through the big grommet behind the clutch pedal and it was a PITA !
I'll take pics tomorrow of the grommet
Here's the final install
Next thing is to install the amp under the rear deck.
Everything is working guy's
Two old JL Audio 12W0-4
rated at 125 watt rms in a sealed box
Kenwood KAC-819
Max Power Output (2Ω) 450W x 1
One sub dead :)
Time for more powerfull !!
almost 10yrs old speaker didn't last long lol
edit: they where 13 years old lol
took the picture before the driver side died lol
New sub and a new vented box :)
JL Audio 12W0v3-4
Dead sub :(
Hi
I'll start off by saying I've installed many subwoofers into various cars and have no problem understanding how it all works and how to do the wiring.
Since this is my first brand new car I want this to be a clean, "stock" looking set up. I'm wondering about running the amp power wires and would like to know what is the biggest gauge I could buy that would still fit in the interior trim channels.
I'm also not a huge fan of just grounding to the chasis of the car and would likely want to run a return wire to the battery as well. With that in mind, would I be able to fit lets say two 4 gauge wires into the trim channels and through the grommet in the firewall behind the clutch pedal?
Hi
I've installed a few subs and it depends on how big the amp is for guage size. I'm getting ready to install mine and I have 8 guage. You really shouldn't have your ground wire more than 5 ft away from the amp and you don't want the amp too far from the sub.There is no difference between the battery ground and the car ground since they are connected to one another. You can find a nut to take off which is grounded and take the nut off, put the ground wire in there and out the nut back on. I would use a flat head screwdriver to remove any paint which might be on it.
I understand how to size wire based on current requirements.
I'm not sure what you mean when you say I shouldn't have my ground wire more than 5ft from the amp. Whether the wire is grounded to the chasis or with a direct line back to the battery the distance the electrons have to travel is the same... back to the negative terminal of the battery.
Electrically I understand that grounding to the car chasis is no different than running a line back to the battery, but the difference is in the quality of the conductor. A pure copper conductor back to the battery is going to have far less voltage drop than the path of the chasis. Between that reason and for reasons in which I may want to pull a heavy load (such as running a large inverter off the sub power lines) an isolated ground is going to be better.
Hello can anyone guide thru some rough patches im having with installing an amp on my (2006 mazda6 v6- WITH the bose system). I got everything ran, im good at installing. Troubleshooting not so good at..its hard when your dyslexic....so here's my issues I bought (1) 1 male-2female rca, I cut the male end offer posed the core on both red and black(mine is black instead of white)I took the shield copper wiring twisted it together....so I have 2 cores exposed(1 red 1 black,I took the copper wire around those cores, separated them from the cores and twisted them together...on my bose sub in the back theres a wire I can disconnect from the sub and goes up about 6 inches to another connector so you can pull the whole thing out...i read how to do it but im stupid and I can't really see the pictures that good...my main question is...on the the factory wire harness thing I pulled off by the sub, I have a 4 wires (blue/red) - (all black) -a (brown/white) - and a (black/red)... i need to know where the (red core rca) - (black core rca) go, and where the vopper shield wire i have twisted up goes on those 4 wires
I am having trouble with my amp to turn on
My pac is behind the headunit with the rca connected to the amp , my remote wire didn't work on the pac so I just used the fuse box for the remote wire and grounded my wire on the passengers seat bolts .
Still no power 3 new photos by Evolution 8 here some pictures
2016 Mazda 6 Sport 6MT
You can check if the remote wire is getting power by using a multimeter. I would also check your main power wire and the ground. Also make sure the fuse for your main power wire and fuse on the amp (if it has one) are not blown. Also check the settings on the amp to make sure it’s set to turn on by the remote wire.
21 - 36 of 36 Posts
