Reviewed 5-21-16
Mazda allows over 1/4" toe-in (measured at tires), front or rear. This will be "in spec" and eat up tires and mpg's. Alignment shops hope to do minimal adjustments for the fixed price deals.
This is an Official Mazda Alignment Spec from the FSM. Thanks to Final Impact:
http://forum.mazda6club.com/3489475-post2.html
-- All MS6 & M6 Models, OEM Align't Specs for each model
M6 OEM Alignment Spec's are also in "the steering pull link" below. [Note Mazda's OEM spec's use degrees and minutes for units, where 17' = 17 minutes = (17min)/(60min/deg) =.28 deg]
These 3 "back-up" links below show Alignments Spec's based on a Shop's Alignment rig software. They may show averaged Generalized Specs for all M6 & MS6 models. Best to use the better link above.
http://forum.mazda6club.com/attachm...6067-alignment-spec-not-good-enough-specs.jpg
http://forum.mazda6club.com/speed6-...t-performed-car-still-drifts.html#post2925490
http://forum.mazda6club.com/attachm...-alignment-spec-not-good-enough-alignment.jpg
Three links work, KJK, 5-12-16
Suggested Alignment Spec
For street use, pay extra if needed, but set front and rear total toe-in at .09 deg +/- .04 deg ( .045" +/- .022" @ Hunter reference tire OD* , or .04" +/- .02" across tire OD ). Rear camber of -1.6 deg MS6, and -1.1 M6 deg (spec targets), +/-.2 deg. [ Be clear about the toe spec units: degrees is typically used]
Ask for their before and after alignment data sheets.
If you're into racing type handling, SPC adjustable front ball joints are a must. Mazda front camber spec is between +.7 deg and -1.28 deg. I'd start at 1.2 deg negative. +/.- .2 deg. This will also reduce excessive wear of the outer edge when enjoying the curves.
SPC Ball Joints
http://www.spcalignment.net/instructions/67330-INS_WEB.pdf <--- Instructions
For autox, drag, or circuit driving, others can suggest more aggressive spec's. But this gets you in the right ball park for normal use.
If you run wide 40 series tires, and don't corner hard a lot at track events, high neg camber (-2 deg or more) will wear out the inner tire edges.
Steering Pull TSB
If car pulls to the right, make sure right front caster is greater than left. Special upper control arms are available to change caster. This link describes the issue and includes includes a pdf link to Mazda's TSB:
http://forum.mazda6club.com/suspension-brakes/196939-car-pulling-right.html#post2749204
The MS6 has same front upper control arms as the M6. Lower control arms have stiffer bushings.
* Hunter uses a Reference Tire Diameter for all of their car toe-in mearurement conversions from degrees to inches or mm's. They use 28.65 inches or 727.7 mm diameter, regarless of the car's actual tire size. For quick conversions to degrees from Hunter results or spec'n displays in inches: 2 x inches = degrees . Note your typical MS6 tire is about 25.6 inches at the tire OD.
NOTE TO MEMBERS:
1) IF you have a link to the Mazda6 alignment spec'ns, even by way of an alignment sheet that includes the spec'ns, please send me a message and I'll include it here.
2) IF a link no longer works, please send me a message and I'll try to fix it.
KevinK2
SPC Ball Joints
Steering Pull TSB
NOTE TO MEMBERS:
KevinK2
