1 - 2 of 2 Posts
The airbag lamp on the dashboard is lightning (with coed 47) sometimes (not always). Is there any reason and solution for that?!
04 Mazda 6 Hatchback (GG) 2.0, 141pk, 104KW - LF17, LF18.
Hello. I am not sure how you are getting a code 47. I am only familiar with airbag codes starting with B however if you have changed anything with the seatbelt, airbag, or seats it is possible that something has become upset/dislodged.
I would check the connector under the seat (yellow plug) as it is really the only part that moves on a semi-regular basis. Make sure the ignition is off and ideally with the batery unpluged before you muck about with anything air bag.
1 - 2 of 2 Posts
