1 - 20 of 614 Posts
I notice that a lot of people have springs questions and there isnt a FAQ thread with comparisons of all springs in it. 6tech has one including shocks and coilovers.....
Tanabe 210 NF: Tanabe
6s: Lowers the car roughly 1.5/.7 inches. Evens out the fender gap from front to back. Personally, I think it lowers more in the rear but thats what the website says.
6i: Lowers 1.2 inches
Spring rate: 3.9kg/mm Front & 2.6kg/mm Rear
Springs were designed for the 4cyl and are the same ones used on the 6cyl, hence why there is only one set of spring rates and the drops are drastically different.
Tanabe 210 GF: Tanabe
6s: Rumored to lower the V6 more than the 4cyl.
6i: 1.2 inch front and rear.
Spring Rate: 4.9 kg front and 3.8 kg rear
Racing Beat: Racing Beat
6i: .75/.5 drop 20% spring rate increase
6s: .75/.75 drop 20% spring rate increase
Tein H Tech:
Tein H Tech
6i: 1.7/.8 inch drop, 4.3kg and 2.6kg
6s: 1.5/1 inch, 4.5kg 3.3 kg
S Wagon: 1.8/1.1, 4.3kg and 2.6kg
Tein S Tech: Tein S Tech
6i: 2.3/1.4, with 4.7kg 2.9 kg springs
6s: 2.1/1.6, with 4.9 kg 3.6kg springs
s Wagon: 2.4/1.7 with 4.7kg 2.9kg springs
Espelir ASD:
1.18 inch drop
Spring rate: 20-30% increase over stock, 4.7kg -3.1kg
H&R: HR Springs
1.4/1.3 inch
Eibach: Eibach
Pro Kit: 1.5/1.4 inch
Sportline: 2.0/1.5 inch
Mazdaspeed:
Mazdaspeed
5-Door 2.3L 22mm ft / 22mm rr
5-Door 3.0L 39mm ft / 24mm rr
Wagon 39mm ft / 41mm rr
4-Door 31mm all around
Increases spring rate 30% over stock.
Sprint
: Sprint Springs
1.8/1.8
B&G B&G
1.6/1.6
Also, if anyone wants to posts pics of their spring install feel free. Hopefully we can get a collection of pics with all different springs on so everyone can get a good idea of what the springs look on different models.
Also note: Lowering springs will have a degenerative effect on your stock shocks. The stock setup has 2.5 inches of suspension travel. The amount that you lower your car reduces the amount of suspension travel your car has. Springs are a cheap and easy way to lower your car for looks, and gain performance in handling. If you are worried about shock life, I would suggest not going with a harsh spring. The mildest spring is the Racing Beats which will have the least amount of effect on your shock life, however the drop is very mild and does not even out your fender gap.
When dealing with springs, since you still must work with the stock shocks, its a give and take relationship.
Q: If I put on these springs, will my car rub?
Springs will NOT be the deciding factor if your car will rub or not. Springs will only increase the frequency of rubbing. The specs of your rims and tire size will determine if your car will rub or not. If you are on stock wheels or close to stock specs, putting lowering springs on your car will NOT make your car rub, it however will increase the frequency of your front bumper getting scratched up. :)
Q: How long will my stock shocks last with these springs?
Well that depends on a number of factors. Your driving style, the spring, and how much wear and tear is already on your stock shocks before going to an aftermarket spring. There is no exact science or formula to determine exactly how many miles you can get on your stock shocks that I know of. Just know that ANY aftermarket spring has a degenerative effect on your stock shocks. How strong that degenerative effect is depends on the spring you choose to put on your car and your driving style.
Q: Im confused..... I want to order Mazdaspeed Springs but I dont know what to order?
If you have a 6s V6 engine, sedan OR hatch OR wagon, get the HATCHBACK/5DOOR SPRINGS.
Members have posted pictures of each model with these springs on......... search for them. I even did a huge writeup why and posted pictures to back it.
If you have a 6i I4 engine, sedan get the 4CYL SEDAN SPRINGS.
If you have a 6i hatchback, I slightly recommend the sedan springs, but the hatchback springs are also an OK option.
Clarification: I have received a plethora of questions on the 6i hatchback so I will clarify on these springs.... there is only one set of springs designed for the hatchback/wagon, and thats designed for the V6 engine. The 4cyl front weighs less than the V6 front (about 200 lbs I believe), so the drop you see on peoples V6 hatchbacks will not be the same if they are put on a 4cyl hatchback. The 4cyl sedan springs have the correctly designed front for the 6i hatchback, but the hatchback rear has a little more weight than the normal sedan rear (about 100 lbs I believe). Because the few cars that I have seen with the 6i sedan springs on them were not saggy in the rear as compared to the saggyness of the V6 sedan springs, I would lean towards putting the 4 cyl sedan springs on the 6i hatchback over the hatchback/wagon springs on the 6i hatchback, although neither is a wrong choice. Its not a perfect or ideal solution, but when choosing between the two, I would lean towards the sedan springs being the lesser imperfection and due to the fact that the hatchback/wagon springs were designed for a V6 engine. Comparing the difference in weights to what the springs were technically designed for, there is a less difference in the rear (100 vs 200 lbs) so I would slightly side with the 6i sedan springs for a hatchback, although neither is ideal and neither is horribly wrong.
Ideally, a 6i hatchback needs the 6i sedan fronts and the hatchback/wagon rears, which is not offered by mazda as an individual set and therefore you would need to purchase 2 sets of springs.
Q: But I still dont get it, I need someone to explain it again..... I have a V6 sedan, why should I order the Mazdaspeed 5door/wagon springs?
When the Mazdaspeed springs were originally designed and came out, the rear spring sagged a lot in the sedan. The springs offered the same drop ALL around and therefore did not even out the fender gap. The drop in the front was good, not too slammed and still gave you a little suspension travel, but the drop in the back sagged and made the car look horrible. Mazda went back and made the hatchback/wagon springs which accounted for a little more in the rear springs. The front springs, IIRC for the Sedan Springs (H14) and the wagon/hatchback springs (H15) are the same exact spring, the difference is in the rear......
I have had these springs on my V6 hatchback the longest and I am very happy with my decision. The fender gap between the front and the rear is dead perfect, they took me a few months to settle but once they did the ride looks great. A bunch of people then jumped on board and bought the Hatchback springs for their Sedan as a recommendation and suggestion by some of us and they found that the difference in weight between the hatchback and the sedan, which is like 100 lbs, didnt really do anything noticeable on the drop and that the drop on the Sedan, after the springs settled, also was almost dead on perfect between the front and back fender gaps.
Here is a picture of SkippyRock's car. He has a V6 Sedan and the Mazdaspeed Sedan springs. Look at the rear.
And here is Philter25s (V6 Hatch) car in when they settled....
And for fun, here is Nashirak's V6 Sedan with the hatchback springs on
4cyl sedan with the 4cyl sedan springs
Mazdaspeed Hatch Springs on 6i hatch
good post definetly a sticky . this should be like the members wheels thread . and just post pics and description of the drop . i wopuld PM DAVECOYNE , and see if he will pin it ,. on the bottom add links to our sponcers that sell these products
Tanbe NF on mazda6 5-door , tends to sag more in the rear the Tanabe NF's were made for the 4cyl sedan and being the 5-door is 6cyl and weighs more than either the 4cyl or 6cyl sedan . the springs are soft ride is almost like stock . tanabe says the srings lower to 1.2 on the 4cyl sedan , on the 6 cyl its more like 1.5 in the rear and more for the front .
on stockers :
on 18" kyowa kr206 wheels with 225/40/18 tires :
here is a link of my before and after pics right after i installed the springs . so in the pics they havnt settled yet . they are a little lower now .
before and after shots
Originally posted by mmarfan@Sep 14 2005, 07:47 PM
You forgot the Sprints
[snapback]508276[/snapback]​
I couldnt find the springrates for them...... any info with a link?>
Also lefty,
On the tanabe's, I had them on my 2004 also and I agree. I just posted what the website says. Since they were designed for the 4cyl, I dont think the specs are entirely accurate. The front definately drops more than the rear and I think the rear does drop more than .7 inches.
Here is my tanabe 210nf front of my car:
Originally posted by Philter25@Sep 14 2005, 07:54 PM
Also lefty,
[snapback]508280[/snapback]​
well thats because we have the hatch , there is more weight on the rear tires
thanks a lot for this post! i was tryin to figure out what springs to get. it's nice to have them all listed in one spot for easy comparison, and pics too!
Discussion Starter #11
For anyone thinking about the Mazdaspeed springs for the hatch....... I was unable to get specs after contacting mazda a few times and finishlineperformance.com
All I got was that "it lowers 1.25 inches"
If anyone has any other info it would be greatly appreciated on the SPECS of these springs.
[snapback]513192[/snapback]​
does anyone have these and could they post some pics? how was the install?
so i am newb to springs, but roughly what is the decrease in shock life if i were to get either eibach pro kit or the mazdaspeed springs for my hatch? could someone explain the effect springs have on the shocks? nice write-up btw philter
Discussion Starter #13
[snapback]515043[/snapback]​
The only people I know with the springs for the V6 is ShaDrag with his sedan. If you do a search for him, he has them and has posted pictures. Also I think Bfrere and ucleadguitar have them for the 6i. I havent seen any pics on the V6 hatch because MS just came out with these for the 5door/wagon. UCleadguitar has the sedan springs on his hatchback.
The decrease in shock life depends greatly on your driving and the roads you are driving on. Some people experience no problems. Others 10k and they need new shocks. A good rule of thumb is the larger the drop, the more pain you put on your shocks. The larger you drop the car, the more suspension travel you take away from the shocks. Any drop over 1.5 inches IMO is on the high end.
I would reccomend the MS springs over the eibachs because the MS have a less drop than the eibachs so given equal amounts of driving and bumps, you shocks will last longer with the MS's over the eibachs.
The installation is moderately easy but time consuming. You need to take off your wheel, about 4-5 bolts, and then drop your stock shock from your car. You then compress the springs and put the new ones on. There are installation instructions for springs floating around. Also, I would reccomend you have airtools and something to take the top of the shock off. I tried the installation on my last car with my wratchet and some of the bolts were VERY VERY hard to get off and I could not get the top of the one spring off.
Ideally, this is the drop I am looking for however I could never purchase springs without knowing exactly the front and rear drop along with the springrates and no one knows what they are, not even mazda, which really pissed me the fawk off. :yesnod:
I have tanabe gf210 on 225/40/18 ride seems alot better than expected, not too much difference than stock. PLUS No rubbing........yet
5dr 6i
5dr 6i
[snapback]515271[/snapback]​
Damn that red 6 with black rims looks smokin!
[attachmentid=7187]
MazdaSpeed Springs
Koni Shocks
18" 5Zeigen Super6
Discussion Starter #18
Originally posted by gunmetal@Sep 25 2005, 12:14 PM
[attachmentid=7187]
MazdaSpeed Springs
Koni Shocks
18" 5Zeigen Super6
[snapback]517113[/snapback]​
Did you buy the springs for the V6 sedan or the springs that were just released for the 5-door/wagon?
Just curious because Im sure the drop differs slightly.
If you lower the car more than an inch, you'll ride on the bump stops.
All but a handful of the springs listed above ought to be listed as "for show only". Riding on the bump stops creates a terribly unpredictable car. Do not run i4 springs on a V6, or you'll ride on the bump stops. Do not run ANY spring advertising a drop of more than an inch without replacing your shocks. Do not run Eibachs pro-kit springs, as they're designed to work with the bump stops, and that's just silly. Having an unpredictable car is fine for street providing you do not drive hard; in fact you may enjoy the ride quality compromise.
I would recommend Racing Beat or Eibach Sportline springs for V6 owners.
Honestly, custom spring rates with Koni's are a better choice than ANY listed above.
If you have any questions about any of this,
:search:
Rear:
Discussion Starter #20
[snapback]518214[/snapback]​
:huh:
I thought the Eibach Sportlines lower the car MORE than the prokit?
Did Stretch finally make a boo-boo? :slap:
1 - 20 of 614 Posts
