Hi everyone!
Could anybody help me, why hasn't the new Sony headunit any sound? I have a Mazda 6 (2gen) from 2011 with Bose system. I tried an Eonon headunit, but i had millions problem with it and I don't want to anymore android'headunit using.
Therefore I bought a new Sony headunit, a frame for the radio and a cable (which make a connection between the mazda original cable and the sony's iso cable). I took care to buy a cable that was compatible with bose system.
After connection, all functions are excellent, but there is no sound. I tried to check other forums to see what might be wrong, but I couldn’t find an answer that could help in my case. Maybe you could help.
The problem is perhaps that the amplifier is not receiving power. I read about connecting the blue cable by the antenna'connector to the white-blue amp cable, but there is no success.
Thanks everybody who try to help me.
Did you check the fuse for the Bose circuits? There may be two, one under the hood and one in the kick panel.
Yes, I checked it. The fuses have no problems. With the original headunit system or with the eonon system everything is good.
I attached 2 photos about the eonon cable system. I think at the blue cables something is wrong, it looks different by me
idk if the wires are hooked up with a one way fitting connector but if they got put on backwards (+ on -, - on +) it would do that
