So this weekend I decide to upgrade the front lights. Nothing fancy, just the Sylvania Silverstars, since they're whiter & brighter than the suckee stockers. Anyways, my problem is that my fog/driving lamps(H3ST) won't work now. Long story short(too late), '05 6S, installed the low beams(H1ST) first, test..., check, working fine. Next, I install the driver's side H3ST, test....., check. Working good, lookin' good, so far. Now, the problem, I install the passenger side H3ST, test...., nope. Check the seating of the bulb & the connection, nope, both H3's not coming on. Damn!! Replace last(passenger side) H3 with stocker...., still neither side works. What else should I be checking for, the H1's are fine. :tear:
most likely a fuse...check the fuse box under the hood of the car...make sure there are no breaks in the fuse. If there is simply replace that bad boy! good luck.[/b]
Color me stupid, but I though the fuses were all inside the kick panel. There are more under the hood?!
