update on this.
Ok mi amigos, this will not be as straightforward as with the 2.3l.
On the 2.3l the cps sensor is a lever that moves up and down. I only found one sensor located right next to the crank pulley so that's got to be ours. It's just a metal cylinder and it's mounting bracket is secured with a single 9mm bolt beneath the sensor. When installed you're looking at it in profile, rather than straight on like the 2.3l.
The Duratec cps will clearly need a mod of the mounting bracket to resecure it in it's new (advanced) position, and I'm not sure how to even approach that. Certainly to do it right you'd have to fab a new bracket to hold it in place.
EDIT: ok on further thought, I dont think this is going to do anything for us at all. Unless I'm wrong, we have a totally different type of cps. It's just a metal cylinder and I'm thinking it doesnt matter which may the thing is oriented. It'll still turn the same info.
