I can almost guarantee no one has done them, and for a street driven car preloading the front suspension really isn't neccessary...
I'm going to take on a front sway bar soon (Pending some info from Corksport), and I'll consider these when I do them, but I won't preload...
Preload a front sway bar??
How would adjustable end links "preload" a sway bar? All they'll do is allow you to balance the bar left to right.
pre-loading is when you put load on the swaybar when the vehicle is at rest. this can be achieved by having the endlinks at different lengths. this is used when a track has mostly left turns or right turns.
Exactly - the only reason to go with adjustable end-links on the front sway for a street car is if they have stiffer poly bushings - or better yet if they have a true spherical bearing eliminating the bushing altogether.
Discussion Starter · #6 ·
Thats kind of why I asked the question....wasn't sure what the application was for street use. Thanks guys.
Wayne
