Im trying to remove the abs sensor from the knuckle so I can pull the knuckle off the car to do a wheel bearing.I got the bolt out but can't get the sensor to pull out .Sprayed some PB Blaster around the sensor and bracket and been prying on it w a thin screwdriver .It seems like the bracket is coming loose but sensor is still really tight.Any advice?
