If you do ANY kind of drop you want to change out the shocks... BUt with a .75 drop it's not the most important thing as your stocks will probably hold up for a while.. just not as long as they would i fyou left it how it is.If you do a .75 drop on the 6s will you have to change out stock struts and shocks?
Also are there any superchargers out for the mazda6s? Or LSD?With all due respect, if you can't afford to do everything at once it's all good. Ride your stock shocks out for awhile then replace them a few months down the road. Or else wait and do everything at once. Lowering the car less than an inch shouldn't be a problem though for the stock shocks.
Sounds like you're using MazdaSpeed springs, which are meant to work with the stock shocks anyway...
