I am in 74.00.200NA, could I just update to the latest version in one update as well? Thanks!You need to upgrade to 70 first, but then after that you can - though it may all be in the same .up package now - I've seen that both in Reddit and here - so I assume it'll update you to 70 then to 74 in one sweep.
YESI am in 74.00.200NA, could I just update to the latest version in one update as well? Thanks!
If your setup has already had the parts upgraded with the current firmware version you have, I don't see why not. 🤔 But I would research a little more...Hi. In the manual it says:
"YOU MUST PURCHASE and INSTALL the TWO GENUINE MAZDA PARTS LAST."
I currently have version 70.00.100eu n and parts purchased in China. Everything works fine including the AAwireless dongle. Is it safe to update and is worth it?
Nice74.00.324A EU N Connect Firmware is now out for NA N , EU N.
NEW 74.00.324A EU N is available
NEW 74.00.324A NA N is available
SYMPTOMS
The following symptoms can be improved by the latest software (Ver. 74.00.324A).
Improved symptoms depend on current software versions.
• If the shift lever is operated quickly while displaying CarPlayTM screen, the rear view screen may not return to CarPlayTM screen.
• When the gear position is shifted into P from R, the screen may not return to the previous condition before shifting into R position.
ALSO NOTE: Do not rely on your Mazda Dealer to update your Firmware for Connect as most never will unless you complain of a specific issue or fault.
Please share the link for Ver. 74.00.324A74.00.324A EU N Connect Firmware is now out for NA N , EU N.
SYMPTOMS
I´m also looking for a answer to this question. The navigation button is driving me nuts and AppleCarPlay are clearly not designed for navigation using this method.Does anybody know if 74.00.324A will allow the touchscreen to work while moving?
Updated to version 74 and nav works again. Very strange, but glad I didn't screw it up.Has anyone had issues with Factory nav not working after updating their headunit? Updated my wife's car last night to 70.0.0.100 in preparation for version 74 and now it says the car doesn't have built in nav but the dealer can install it. And yes, i put the sd card back in after everything was complete
